Question about Jenn-Air JED8430 Electric Cooktop
I have a client that wants to remove a granite tile backsplash in their kitchen, however they do not wish to remove the current countertops. What methods can I use to seperate the backsplash from the countertop? I am not certain how the backsplash is currently being held in place, ialthough I know it will not budge.
    Genius:
  • 1,605 Answers
Two part epoxy specially made for granite.
to take just the backsplsh, you need a dimond saw to cut it. polish it. no other way I know.
Posted on Jan 08, 2009
What if there are no hold down brackets on the cooktop and you still cant get it loose
Sounds like someone glued it down. You're going to have a fight on your hands. Maybe this can help:
How to Remove Countertop That Has Been Glued to the Cabinets eHow
Dec 02, 2014 | Cooktops
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
I just bought a 7904427 electric kenmore cooktop, which isnt installed flashed to the countertop, there is 2 mm gap between countertop and cooktop, cooktop sits on the 8 brackets instead of the flat...
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Jan 09, 2011 | Kenmore 30 in. 42701 / 42702 / 42709...
Remove embedded/inset smooth electric cooktop
HI they just sit on the top with brackets holding from the underside or screwed in from under the top sounds like this was put in the tiled after they arestuck downfwith double sided tape as well some times , if nothing works you could go through the top it breaks like a car windscreen hope this helps
Jan 25, 2010 | Cooktops
New granite countertops big circle spots on.
They suggested a dryer because they thought the stone had absorbed a liquid and was causing the stone to darken. This is common on unsealed granite. If you put a sealer on the counter tops however, whatever it is you see there will remain under the seal. I would ask the installer to come out and take a look at it. If they are unwilling, the Home Depot has a cleaning kit sold in the kitchen counters area of the store made by a company you can call and they will ask questions about the problem and provide advice on how to fix it. They are extremely helpful with free suggestions as well as stuff you may be able to purchase to fix the problems. In any case, granite is sensitive stuff and while it is physically durable it seems to be extremely sensitive to stain and etching and learning about proper care, cleaning, and dos and dont's will save a lot of heart ache and time for you down the road. (For instance oil absorbing into the stone is a several day ordeal to fix). Good luck with getting the results you want. If you did find a specific solution please share it here.
Dec 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Aug 07, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Seperate a granite tile backsplash from an existing countertop
the back splash should be held on by silicone or glue very seldom are they screwed on i would bet it is stuck with adhesive silicone so score around the outside of the splash with a utility knife the remove it scoring around the outside will prevent sheet rock damage
Jan 08, 2009 | Jenn-Air JED8430 Electric Cooktop
I can not separate the glass cooktop from the granite surface.
alot of installers will use a silicone glue to "seal" the unit to the countertop. what happens is that means you cant get it out without cutting the glue off first.
it could also be that the unit is very tight in the countertop.
also did you remove the "hold down" screws from underneath the unit first??? there should be a screw on each side below the unit.
one more thing... do you have a gas line under your counter? if not be sure you can get a gas line to it before you try to remove the old unit. most homes have a finished ceiling under the kitchen and it would be almost impossible to install a new gas line if its not already there.
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Granite installation didn't get flush with slide-in range
suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
Sep 04, 2008 | Cooktops
Removing and reinstalling
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
Apr 07, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
161 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
