Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave power interruption
Everything works until you start to cook, then after about 3 sec. the power cuts off and the display says there is a power failure, check your food. There are not power issues other than that.
  • 883 Answers
The unit may be detecting a mal-functioning magnetron.
Posted on Jun 02, 2007
My microwave shuts off, black no power when ever I cook tv dinners, potatoes etc. after 2.5 or 3 minutes. After 10 minutes or so, power comes back on and it displays PF. lots of steam inside after.
Hi Kerry,
"PF" is power falure if you didn't aready know this. It sounds to me like the coolig fan might be running slow or there is blocked or restricted air flow through the unit. This cooling fan is only for the HV transformer and magnetron. Sometimes you may get air flow around the door but this is incidental. The PF tells me that the power is being interrupted either at the power source (wall outlet or circuit breaker) or the magnetron TCO is cutting out. It also could be a bad magnetron running too hot. As far as the steam goes, I usually just leave the door open on my microwave for 10 or 15 minutes to let the condensation evaporate.
Jun 25, 2015 | Hotpoint RVM1435 Microwave Oven
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
GE Spacemaker JVM 1631: Starts working and stops 3 sec later??
your magnetron is leaking RF do not use until you replace the magnetron, it is interfering with the pc board
Feb 05, 2010 | GE JVM1631 Microwave Oven
When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2009 | Emerson MW8107WA Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave cuts off after heating for about 3-4 minutes
There is a overtemperature device inside that is shuting you down until things cool off. Take the cover off and clean up everything as much as possible. Grease from the cooking can get all over everything inside and collect dust buildup enough to obstruct the airflow and cause overheting.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
New microwave not starting
Chances are the oven is designed for 60HZ and your supply is 50Hz. This will cause the unit to shut down because it thinks it is not getting the proper "interrupt" signal from the power line. You can check the owner's manual (or model number tag) and the manual for the converter.
Apr 20, 2007 | GE JES738 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
256 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
