Hello, I need instructions on how to get apart a sony ericson w595 so that i can replace the lcd screen.
Thanks.
Hey guy!
It's quite easy and done in about 5 minutes!
You just have to remove the aluminium-panel on the backside of the display-slider (when slider is opened and you look at the mobile from backside)! This part is fixed with adhesive and so you can remove it carefully by lifting an edge of it with a thin slotted screwdriver (for instance) and then insert something like a credit card in this lifted edge an remove the whole panel with it.
After this you'll see two little screws you also have to remove before you can take off the front-cover of your mobile. Now there is only one screw left to remove. It's on the front-side beneath the display.
When you're done removing all this screws, you have to be very careful. The old display can be removed by disconnecting it's flex-cable from the circuit board (this little board you just removed the mounting screw from, the cable-connector is on the backside of it).
Now you only have to insert the new display, connect it to the circuit board an do all steps in reverse to assemble it again.
Http://www.formymobile.co.uk/w595disassembly.php
this site will show u how to do it in picture form .
HElp my sonr ericson 595 won't turn on or off it just say sony ericson on the screen wat do i do??
my LCD of w595 have broke.i need to repair
Have the same problem... but where can i get a new LCD screen? Well i think its the same problem, i can still turn it on and off, theres no cracks in the screen and i can still answer calls, i just cant see anything...
My w595 phone's screen cracked in my pocket on a night out, causing a 95% black display :0
I can see a little bit of screen when I apply thumb pressure to it but it really isn't workable. Where is the best place to send my phone for repair?
The kind of ham-fisted chap I am I'd break the li'l beauty if I tried to do it myself.
I dare not do it myself.. Where's the best place to send it off to?
Thanks very much. The only thing is, I can't tell from your instructions where to find the other screw (the one at the front). Otherwise, great!
Can you help?
i have a crack in my sceen and i would like to know how to change it
