Question about Elite Sl 3000 Ul Sliding Gate Operator
Gate will not completely close.
It was closing to about 1/8 of an inch before. After an ice storm it started closing to about 2 inches!!!
Do I need to adjust the chain? and how?
Most likely your chain is not going to be your problem. When you pull the cover off of your SL 3000 there will be a little rectangle box on top. There is either one or 2 screws holding the lid down...loosen the screws and take the lid off. Inside there will be a long screw drive with 2 plastic nuts with teeth.At either end of the screw drive you will find a switch that one of the nuts should be resting on. (these are your limit switches that tell the motor when to stop) Run the gate open and closed...when you run it closed see if it is hitting one of the limit switches when it stops. (turn off the power) If so, hold back the plate keeping the nut in place and move the nut further away from the limit switch.(don't move it too far so that you don't slam the gate too hard into the catch post and hurt the post/gate/motor) Turn the power back on and run it again. Repete this untill the gate is stopping where you would like it too. e-mail me with any further questions tgutierrez13@gmail.com
Posted on Jan 10, 2009
How to bypass ignitino on gsx650f
Instructions
    • 1 Measure the chain's tension with a ruler. Move the center point of the bottom half of the drive chain with your hand. Take a measurement of the chain's movement as you push the chain up and down as far as it will go. The chain should have a free range of movement between 0.8 to 1.2 inches. If the chain's free range is greater than 1.2 inches, you need to tighten the chain. Alternatively, loosen the chain if it has less than 0.8 inches of free movement.
    • 2 Loosen the large nut on the left side of the rear axle with a 32 mm socket and a socket wrench. If more leverage is needed to loosen the nut, use a long-handled breaker bar.
    • 3 Loosen the chain adjuster blocks on both side of the rear swing arm with a pair of 10 mm wrenches. Hold the blocks' adjustment bolt's head steady with one wrench and loosen the bolt's lock nut with the other wrench.
    • 4 Turn both adjustment bolts an equal number of turns with a 10 mm wrench to adjust the chain's tension. Turn the adjustment bolts clockwise to loosen the chain, or counterclockwise to tighten the chain. Check that the edge of both chain adjuster blocks are evenly aligned with the adjustment marks imprinted on the swing arm.
    • 5 Check the chain's range of free movement again. Make adjustments as needed until the chain has a free range of movement between 0.8 and 1.2 inches.
    • 6 Hold the adjustment bolts steady with a 10 mm wrench and tighten their lock nuts against the chain adjuster blocks with a second 10 mm wrench. Tighten the axle nut to 72.5 foot-pounds with a 32 mm socket and a torque wrench. Check the chain's tension again.
Jan 15, 2013 | 2004 Suzuki GSX-R 750
Primary chain hitting case on clutch housing, cable nearly fully adjusted clutch slips if adjust any more. bad grinding noise from chain hitting case can i adjust clutch any more in housing?
The primary chain adjustment has nothing to do with the clutch. Take the small upper inspection cover off the primary cover and use your finger to check the primary chain tension. It should have 3/8 to 1/2 inch up and down movement in the top run of the chain when the engine is cold. To adjust, loosen the lock nut on the primary chain adjuster on the bottom of the primary case. Turn the screw upward to tighten the chain, downward to loosen. Once set, tighten the locknut.
To adjust the clutch, loosen the clutch cable adjuster as much as you can. Remove the derby cover from the primary cover. Remove the spring and the locknut. Turn the adjuster screw counterclockwise as far as it will go. Turn it back in 1/4 turn and replace the lock nut and the spring. Replace derby cover. Adjust the clutch cable so that you have about a 1/8 inch play at the hand lever.
Good Luck
Steve
Apr 29, 2011 | 2005 Harley Davidson XL 1200 R Sporster...
Have a mac 3516 35cc the carberator is way out of adjustment where do i set idle and gas adjustment screws at
I have always found that a good place to start was to close both completly shut then open 1 1/2 turns. On idle adjust to where it will idle good and chain is not moving. At run speed adjust slowly to where it runs the smoothest at max R.P.M.s. Hope this helps.Thank you.
Dec 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain replacement
Usually the loose rear wheel has enough motion to allow the chain to close up. You may have to back off the wheel position adjusters to get this to happen. Push the coupling link through the chain ends toward the wheel side and install the free link, then the clip so that the closed end is pointing in the direction of normal chain motion. Adjust the wheel to set chain tension so that the chain will move about 3/4 inch up and down. Balance the two adjusters so that the tire is centered between the swing arms. Tighten the axle securely, then tighten the chain adjusters firmly. Recheck for free play in chain as above. Make sure the clip is properly seated in both pin grooves.
Aug 01, 2009 | 2005 Yamaha Xv 250 Virago S
Chain needs to be 1/4 inch play adjusted that then sit on bike and chain seems to tight its sounds like its grinding do i adjust chain when sitting on it when its tight or with no weight
1/4" is too tight, you should have one inch minimum. Check it while the bike is upright sitting on the tires. Move the longest part of the chain up and down and you should have one to one and a half inches of play.
As a comparison, my BMW 650 has seven inches of suspension travel at the rear and my spec is 45 to 55mm which is about an inch and 3/4 to two inches.
Apr 27, 2009 | 2001 Honda XR 650 L
Garage door opener chain out of sync with door
There are two white screws on the sides that adjust the limits. Adjust the "down" screw less. You should have to turn the screw 4 full turns for eight inches. After you make this adjustment, test it without the door being hooked up to prevent damage to the door or opener if it tries to close too far.
Feb 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Elite Sl 3000 Ul Sliding Gate Operator Logo
784 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
