Question about HP LaserJet 2420 Printer
Change from envelope to paper mode?
How to change from envelope mode to paper mode?
    Genius:
  • 2,120 Answers
Scroll through the paper handling menu and select CASSETTE FIRST
Posted on Jan 08, 2009
Kyocera FS4020 - how do I get it out of envelope mode
When you start print there is a option to change it,i guess is like "properties" hit it and change the configuration.
Apr 18, 2012 | Kyocera Mita Office Equipment & Supplies
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Where do you place the envelope on the printer to feed it in
You put the envelope between the adjustable paper guides, with the side you want to print on facing up. Then you have to manually change the paper size by pressing the "Adjustable Functions" button to display "1.Paper Settings." Next you have to press the "Set" button twice, which gives you access to the Paper Size option, where you can select the envelope type with the + and - buttons. After you print your envelope you have to change the paper size back to the size you are using in the tray.
Mar 23, 2010 | Canon imageCLASS D320 Digital Copier
How do print on an envelope with the MP830
you should see a picture of an envelope in the paper tray area. remove any other paper and align the paper guides to the envelope. If you are using WORD make sure to change the paper type to the correct envelope size.
Jan 06, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I am trying to print envelopes (using MS Word mail merge) and printer says "paper mismatch"
first change the page layout setting in the document to envelop size then try to print ..... go to page layout size option the change the paper size to envelop then try to print ......
Dec 14, 2009 | HP Officejet 6310 All-In-One InkJet...
Ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
May 24, 2009 | HP LaserJet 4300n Printer
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
Printing Envelopes
Must use Tray 1 bpass to feed labels, on word change media type to envelopes ie page size,paper type and on printer set tray1 paper type to envelopes
Dec 11, 2007 | HP LaserJet 4100n Printer
HP LaserJet 2420 Printer Logo
44 people viewed this question
Ben Johnson
