Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Whining water heater.
I have a 2 yr. old 40 gal. gas water heater. When I turn the hot water on in the bathroom I get a low whining noise that last until you turn the water off. What could be happening?
  • 163 Answers
Hi!!! You have a water pressure problem.Also clean your water heater ,get all the hard water out drain it and fill it up again. Good luck...If it dont work then call 1-800-512-buck.
Posted on Jan 08, 2009
    Sergeant:
  • 378 Answers
First, I suggest that you flush your waterheater out, this is something that should be done yearly to get out sediment that can do damage and shorten its life. Second, it sounds like water hammer but it may be the water pressure, it could be too high. Do you have a water regulator anywhere near the heater. I am going to send you to a website that may help explain a few things and maybe from there you can resolve what is going on, it can be several things and at least this way you are learning.
http://www.howstuffworks.com/framed.htm?parent=question89.htm&url=http://www.fac...
http://www.howstuffworks.com/framed.htm?parent=question89.htm&url=http://www.nat...
http://www.stemdoctor.com/hot_water_heaters.htm
I hope this helps and good luck!
  • 89 Answers
It could be that your pipes are starting to get clogged for mineral deposites
  • dragon_rag27
    dragon_rag27 Jan 08, 2009
    your best bet would be to get a product to clean out your lines it should help eliminate the whining noise if it doesnt please post back and tell us
  • 19,396 Answers
The high piotched noise is not from the heater, it is because the lines ar partially obstructed.
  • Ginko
    Ginko Jan 08, 2009
    The high pitched noise is not generated by the heater itself, but it is usually because the pipes are obstructed with lime or oxide.
    Check that pressure looks fine on the heater indicator.
    Sergeant:
    Novelist:
  • 326 Answers
It might be due to aNY OF THE VALVE BLOCKING THE WATER TO FLOW FREELY.the valve might be loose.
    Sergeant:
  • 290 Answers
Is the whine coming from your faucet or the water line in the bathroom. I get this one my shower because I have a massage shower head if I don't pull the lift knob for the shower all the way up.
Bradford White 40 gal water heater,works fine, but has started whining when not in "low" setting. Seems to only do it during showers, or when temps drop outside etc. Only lasts a few minutes
it is possibly a high frequence '"water hammer" from a failing tap washer
call a plumber to replace all the tap washers especially the shower hot water tap washer
water hammer is when the water flow is intermittently interrupted ( (normally as banging pipes) but when it is fast it appears as a whistle or squeal
Dec 17, 2016 | Water Water Heaters
Getting really hot water to the kitchen but only tepid hot water into the bathroom and ensuite. Do not need to put on the cold tap at all in the bathrooms but you can't hold your hand under the tap in...
If some taps have really hot and others luke warm, then you might have defective mixing valve, check valve, or crossover on single handled faucet.
http://waterheatertimer.org/Crossover.html
Crossover can also cause stacking event. Stacking could be part of puzzle.
http://waterheatertimer.org/Stacking.html
Once crossover or check valve or mixing valve problem is solved, if you have really hot water to some taps, then turn down thermostat to avoid scalding.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Add a comment for more help.
Jun 13, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water leaking observed from the bottom of the tank. What's the problem? Should I replace the old 21V40-2 unit? if so, what kind of tank is ok to replace the present unit? What's the price and installation...
If water heater is leaking, then open following 2 links to avoid tank rupture and troubleshoot leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Water-heater-is-leaking.html
Open following link if you want to install your own gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To have gas water heater installed, can run $2-300 for installation plus cost of heater.
40 gallon natural gas water heater at Lowes starts at $300+, and tanks with longer warranty cost more and last longer.
If you maintain the tank: keep chemicals out of same room as water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Apr 07, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a 40 gal Whirlpool single element 3500 mobile home hot water heater. I have replaced the element thermostat high pressure valve (because it was leaking) & flushed for sediment. In morning I wash...
A 40 gal. electric water heater will give you aprox. 32 gal. of hot water in one setting, since they do not reheat as quickly as gas. So if you are using a newer 1.5 or 2.0 gpm shower head. You could take a 16 minute shower with straight hot water. If you are running 2 new shower heads at once you could get 8 minutes. If you using the tub spout the times decrease. Some of my customers like to turn up the temerature on the thermostat a little so they can mix more cold and get it to last a little longer. Be very careful doing this.
If your water heater has a lot of calcium built up in it the times will decrease.
With out seeing the heater, you mention it is a mobile home heater so I am guessing that it is bottom fed.
I hope this has helped.
May 09, 2010 | Water Heaters
Water will not stay hot long enough to shower...not familiar with any of these thermal expansion tanks and can't find any info on vacuum relief valve---40 gal water heater is 18 months old....any...
Turn the gas knob up. There's a dial on the front (probably red) and it will have settings on it. A B and C. Turn up to desired temp, but be careful of faucets if there are children in the house. Good luck
Dec 30, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Amtrol Boilermate makes whining noise
I had also this problem before, same with buzzing sounds on my Amtrol Boilermate and all I had to do was to call the local dealer and they have got it fixed.
May 05, 2009 | Emerson Part UWL Chrome Ultrasystem water...
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
23 people viewed this question
Top Protech Systems Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
