Question about HP Photosmart 2575 All-In-One InkJet Printer
Printing problem with photosmart 2575
The printer goes through all self tests and alignment proceedures as is supposed to and evertthing appears to be working correctly, yet when I try to copy items via the copy button, my resulting printout has a strip of solid black about 3/4 of an inch wide on the printed copy. Any suggestions or solutions would be appreciated. Thanks!
  • 62 Answers
Think the printer need to be serviced by a qualified tech.
Posted on Jun 02, 2007
Loaded new print cartridges went through alignment check /scan error message none alignment.Reloaded cartridges went through same proceedure same result.unable to print anything
Are you checked working condition of scanner before replacing the cartridges?. If scanner is not working align process could not completed..cancel the align process then you can able to take prints..
Sep 10, 2011 | HP Photosmart 4180 All-in-One Printer
My C3150 is not printing in color and I am pretty sure that the settings are correct.
You need to calibrate the printer. You are not supposed to skip this process. After loading a new printer you need to do the calibration without fail. You could get the black ink into work back. For this you need to run 'Self Test Diagnostic'. Along with this you need to also run the 'Print Cartridge Alignment'. This would help you to get the black ink to work.
Nov 16, 2010 | HP Photosmart C3150 Printer
A message comes up on the printer window saying remove and check colour cartridge. the cartridge is new and connections look ok
clean the cartridge contacts.... then align it.
To align the cartridges from the front panel follow the steps:
1. Press Setup.
2. Press 5, then press 2.
This selects Tools, and then selects Align Print Cartridge.
Mar 13, 2010 | HP Photosmart 2575 All-In-One InkJet...
White lines across my printing.have cleaned print cartridges and aligned cartridges. Still white lines are through all solid areas.
havwe you tried manually cleaning the cartridges with clean cloth and a dab of alcohol? if not pls do and tell me what happens
Jan 08, 2010 | HP Photosmart 2575 All-In-One InkJet...
Hp 2575 wont print documents. 7 pages in queue
Ok now before hand I am warning you,this may just be a printer problem and so rate me as per the solution and not for the answer,cauz the printer ur using is a machine and Im a Human,two diffrent things altogether.
Copy and paste the link in the address bar of your browser and follow the document,its the same for all operating systems
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01893667&cc=us&lc=en&dlc=en&product=441240
if this doesn't work call up hp tech support at 1800-474-6836 ,cauz there may be something wrong with your printer hardware and see if you can get a hardware upgrade for a 30-40% discount with an extended service plan at a 60-70% discount
Dec 20, 2009 | HP Photosmart 2575 All-In-One Printer,...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
HP PhotoSmart 2575
hmmm..sounds like a new set of drivers might be just the thing.
get em here
Mar 05, 2008 | HP Photosmart 2575 All-In-One InkJet...
Not printing...
Please print a self test page by following steps. Check all the colors printed perfectly.
1. Press Setup on the All-in-One and press arrow keys to select Print report menu and then Press Ok.
2. Then press Ok again to print a test page from the All-in-One.
Let me k now from which appllicaiton you are trying to print. Let me know if you are able to print normal text documents also color documents or not. Need a description of the issue.
Thanks
Dec 24, 2007 | HP Photosmart 2575 All-In-One InkJet...
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
61 people viewed this question
Clive
Clive
