Laptop won't power up dies in the middle of movie-won't power up
Brand: Acer Aspire 5672 WLMi New system similar config for $399 Best buy Specs: HD 120 GB, Ram 2GB, CPU Intel 1.8 Dual Core, DVD RW, Web Cam, 6 in 1 card reader, Blue tooth, ATX 1600 Radon, Wide screen 15.6 in Display + XP home + MS Office Symptom: When connected Power supply LED green Flickering, battery charge LED off, Power supply LED off Test performed (from Acer knowledge portal): If everything is plugged in correctly and it still will not poweron, follow these steps to complete a 'power reset' of the notebook.
1. Unplug the ac adapter. Keep ac adapter unplugged.
2. Remove the battery and keep the battery unplugged.
3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
4.Release the power button and plug in the ac adapter ONLY. (Please notethat a power indicator light should be lit on the ac adapter when it isplugged in).
5. Normally power on the notebook.
6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Deduction: Inconclusive. The battery indicator light does not light up. Suspecting the Adapter but it could well be the mother board.
Did not try the multimeter test to determine out put of Adapter since Adapter LED is Green when not connected Adapter specs: Delta Electronics, inc Model: ADP-90SB BB; Input 100-240V~1.5A 50-60Hz; Output: 19V 4.74A Resources: AcerTech support for warranty 8008162237 - note system is out of warranty
AcerTech support $2.99 /min: 8776102237
Tech says: it is the Mother board and I need the replacement board, says there is some fluid leakage, can some one give a place to locate compatible mother boards or give me their opinion on this issue?
    Master:
  • 413 Answers
You would probably be better off buying a new notebook. Not sure how tecnologically advanced you are but it seems you already did the troubleshooting yourself. But i am very interested in the a/c adaptor output. If the led on the adaptor is green that just means that it is getting power from the wall.
What did you mean by fluid leaking out?
It could be the mobo (motherboard) or it could be the connections from the power to the machine. If you want to put a new mobo in I have to warn you that taking apart a laptop is VERY difficult and I do not recommend this unless you are a PRO. This is just about the only link i can find to buy a new board. If you google your laptop model you will find out you definately are not alone with this problem
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=1183
Please don't forget to rate my response and let me know if there is anything else I can help you with.
Posted on Jan 08, 2009
4 Suggested Answers
SOURCE: what link that i can
You can access http://support.acer.com
Thanks and regards,
Anil
Posted on Sep 26, 2010
Geekman
  • 32281 Answers
SOURCE: driver for my acer 5672
Normal 0
Download the drivers from the Acer WEB site. Make sure you select the model of your laptop and the XP or Vista version of the drivers you that require and it matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Posted on Oct 26, 2010
Bluetooth function key in acer laptop
Here'a user manual: http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS3000-5000_UG_ENG.pdf I looked at the specs, I didn't see a Bluetooth Adapter listed for a Acer Aspire 5004 wlmi? Open the Control Panel, do you see a Bluetooth Icon? Open select settings.
Jan 18, 2013 | Acer Aspire 5004WLMi Notebook
Acer spire 5672 wlmi
Laptops usually have the graphics chip built-in on the motherboard and the video RAM is shared RAM (uses part of the main system RAM).
Try reseating the RAM modules and if it still does not work then take the RAM to your friendly computer repair shop to test the RAM.for you.
Dec 30, 2012 | Acer Aspire 5672WLMi Notebook
Driver for my acer 5672 wlmi
Normal 0
Oct 26, 2010 | Acer Aspire 5672WLMi Notebook
Acer Aspire 5672 WLmi: Near - Black Screen
check your inverter try to use to other inverter...
Sep 10, 2009 | Acer Aspire 5672WLMi Notebook
Acer 3001 Wlmi CMOS Dead
The best place to search the manual from this site link
http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/3b1edf692d19ce1e48256fd600068b2e?OpenDocument
the manual is here,it covers specs etc....
Have you tried ac power pack without battery attached?
if it is a cmos fault then battery will be on motherboard
battery number should be on battery
Jul 09, 2008 | Acer Aspire 3000 Notebook
I have a acer aspire 5672 WLMi and i need a new motherborad for it. It's had water damage and the rules out exchange ones. Where can i source a new one or just fined someone that can supply me with a...
i would be thinking about getting a new laptop if i were you. motherboard swaps are tricky to do yourself, expensive to have done for you and there's no guarantee it will work because the water might have got in to other components. a new laptop will come with a full guarantee and cost you £400
Apr 15, 2008 | Computers & Internet
Acer aspire 5100 model bl51
dear friend,
this is your system board fault
this is due to southbridge (ich4) or ATI (ixp460) dry sold damage.
you should change this ic to fix this.
go to the best repairing center near you.
Apr 09, 2008 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
516 people viewed this question
David Payne
David Payne
