Question about Kenmore Oasis HE 27082 Top Load Washer
Sometimes,water leaks out from under washer. the amount is cleanable with two large bath towles. Machine is just out of warrantee. Please advise
  • 4 Answers
I suggest that you check the screw holding pump motor to pump, if they get loose water will leak
or check the short hoses from pump, clamps may abe loose
Posted on Jan 09, 2009
Water large amounts on floor of shut off machine
To sufficiently inspect your washer to determine where to leak may be coming from, please review the following link:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
If there is a huge gush of water coming from the washer as soon as you begin the fill cycle, this is commonly caused by a small air hose on the side of the washer drum that connects to the pressure switch. If this air hose comes loose,the water will pour from the wash tub as it begins to fill. This is an easy fix, if that is the only problem.
Another cause, can be a water inlet valve that is leaking by, or a pressure switch that does not keep the water supply shut off when not in use. This will cause the tub to fill up and spill over. The following link explains how to check for this as well:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Read through the information provided and let me know if you are having problems determining the cause of your problem. Please post back with your MODEL NUMBER so that I may be able to accurately determine how your washer is configured. I hope you find this information helpful.
Mar 01, 2010 | Kenmore 44102 Front Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Bearings are going, lots of noise from drum when moved by hand
You have diagnosed the problem yourself. Now you need to get a quote for the repair, which is a major job. Call around your local repairers and see if they will give you a rough estimate, without having to pay for a call out.
You might find it is better to replace the machine.
Also always best not to overload the machine. For example a 5Kg machine does not mean that it will take 5KG worth of dry towls. Imagine the weight of the towls once soaked. That will probably be 3 bath towls max.
Good luck.
Ash
Oct 22, 2009 | Candy CNW156 Front Load Washer / Dryer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Pool of water in the drum if I let the clothes sit.
this is a very comon problem, not really witht the machine though. well i guess it is now.
you have debris / change / other stuff.... lodged into the pump
remove the lower access panel, disconnect power, there is a screw out portion on the pump, nail catcher. remove it and catch all water that comes out with a towl. unscrew it slowly to allow the water to slowly come out, or it will make a mess.
the clamp that secures the drain boot to the tub, loosten it and remove. use a large towl to catch the watter that comes out.
remove the spring clamp from the drain hose and remove the drain hose. again use a large towl to catch water. disconnect pump power supply and remove the screws that secure it to the washer, remove pump.
clear all debris from the pump and check to see if anything has damaged any impellars in the pump. do this with your finger.
clean out the rubber boot as well.
reasemble in reverse order.
before the access panel is put back, start the machine and visually check for leaks. if it leaks reset the rubber and clamp where it is leaking.
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
My GE WBXR1060TAWW clothes washer is leaking significant amounts of water. It seems to be draining correctly, but there is still some water left in the machine after running. Please advise. Thanks.
you have something stuck inside the Washing machine pump assembly,you could tip over the machine disconnect the drain holes and look in the pump and clear what ever is jammed inside. <<<Remember to disconnect the power cord first>>
Apr 21, 2008 | Washing Machines
Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Feb 18, 2008 | Kenmore 23822 Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
