Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Esp.3 printer not working
Less than a year old printer..First replacement of ink..no worke.Can not clear.Paper malfunction lite,,will not copy or clear on the computer..new paper and the right size,,help gary,,I don't want to junk it....
Don't junk it. Call Kodak support and they will send a new printhead. That should be all it takes. I have had my 5300 for just over a year, just replaced the printhead and it works like a charm!
Posted on Jan 15, 2009
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
USELESS! I guess the life of an ESP 3 is up to a year, because after Kodak replaced my first ESP 3 with a second, I'm now having issues. It's also MOST frustrating that if one cartridge is empty and...
Regarding the empty ink cartridges, ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Regarding the printer not being able to detect the size of the paper, you probably need a firmware update. Here is the support information from Kodak website.
And I have to agree with you, printers don't have a very long life cycle, but you should get at least 2 years out of it! Good luck!
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Kodak ESP-3 less than a year old. When it prints, there are bands of faded image throughout the first page and the whole page is faded as if the ink cartridge is spent (but we have replaced it...
Some (not all) of the ink-jets that spray the ink onto the paper have been clogged. Thus, what should *NOT* be WHITE on the paper remains as WHITE.
Start the Kodak Printer "utility" software, and run a "print-head-cleaning-cycle", to unclog those jets.
If a few of those cycles fail to improve things, take the printer to a qualified technician, for a more-thorough cleaning.
Oct 10, 2010 | Kodak Office Equipment & Supplies
My Kodak ESP 3 black doesn't work. I have ran
It sounds like you need a new printhead. The Kodak ESP 3 works in two stages, you have a printhead which is what transfers the ink to the paper then you have the ink cartridges. Change the printhead. You can try to clean it also, by removing all the inks. Taking the printhead out and soak it it warm water to dissolve the clog. Sometimes it will work.
Apr 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I clear a paper jam in the Kodak ESP-3 can't get to the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Jan 17, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Changed ink cartridges but printer still not printing clearly
Try to clean the printhead just press and hold the COPY and CANCEL button On you printer. And you will hear that the Printer or printhead will move it means it means Printhead cleaning is in progress. and also reseat the ink cartridges.
Make sure your using the recommeded paper the Deskjet or the multi purpose paper
if this issue wont resolve the problem it means the nozzles of the printhead is already clogged please call kodak and have printhead replacement Toll free 1 800 421 6699
Nov 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My ESP 3 wont print have changed both ink still wont Why?
HAVE KODAK ESP RECENTLY CLEARED PAPER JAMM
NOW IT S NOT PRINTING OR SCANNING
Sep 09, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Showing paper jam, but have no paper jam and the start button won't clear. HELP!
1. Unplug and re plug in the printer resetting the printers sensors.
2. Check where the ink cartages go sometimes paper get stuck in that area.
3. it might also have to do with a faulty paper sensor or an hardware malfunction.
If the printer is less than a year old you can contact tech support for the maker of the printer and get it replaced.
Hope this helps you...
Please rate how well I help you.
Thank you
Aug 22, 2009 | Dell Office Equipment & Supplies
Printer will not print clearly
im sure you have heard this put are you sure you have the right driver, Or your printer cartridge could be dispersing too much ink at one time try replacing them.....
Driver Download
Apr 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
