Question about Samsung Digimax S500 Digital Camera
It dont turn on
I have a Samsung Digimax S500 and every time i try to turn it on it turns on, but after that it beeps 3 times and it shuts off, the lens stay in their place.
  • 10 more comments
  • Zoltan Vegh Jun 02, 2007
    im test with and without the memcard, but the problem is still remain...
    Yes it work without a memcard.. it has 8MB "onboard" memory. My brother use the cam a few day, then buy a 1GB card..
  • Zoltan Vegh Jun 03, 2007
    i dont know how can i clear the internal memory..
    sorry, my brother use the cam before he buy the memcard, and then using it a little. And now we cant to turn on, just beep 3 times and do nothing else.
    ps. Sorry for my english
    thak for your help
  • Anonymous Nov 01, 2007
    S700 Camera won't turn on. Comes on briefly and then beeps three times and turns off.
  • verdugo Nov 05, 2007
    the camera wont turn on at all
  • Anonymous Nov 14, 2007
    My camera wil turn on without the memory card but not with it!
  • BettyCrocker Dec 02, 2007
    We turn the camera on, and then it will be on for a few seconds, and then it beeps three times. After that it will turn off. We can't figure out what's wrong.
  • Anonymous Dec 14, 2007
    When I want to turn on the camera it doesn't turn on or open the lens, all it does is beep 3 times and shuts off. The memory card was remove to see if that was the problem and it wasn't. Than we put the memory card back in to see if it would work again and all it did was beep 3 times. Please HELP me fix it.
    Thank you,
    Mrs. Lester
  • HoosierinFL Dec 21, 2007
    My camera does the same thing - 3 beeps and then it shuts down. Only reply if if you have a solution on how to fix it. Sympathy cards are welcome but I gotta find a way to bring this camera back to life. HAAAAAALLLLLP!!
  • Marthakiinz Feb 03, 2008
    I have the exact same problem with my praktica camera and i tried twisting the lens BUT the lens isnt out enough.. its only about 5 milimetres out.. mi fingers dont even fit around it.. i tried gently with my teeth but that duznt help hahaha..pleeease help.. and when i turn the camera on the lens doesn't come out or anything it stays in the same 4-5mm place.. and i really need my camera to work :( Pleeease help me!!!! I dont read mi mail so will sumbody add me on msn [email protected] Or go onto my bebohttp://Ya-Stupid-Bitch-x.bebo.com And tell me a suggetion PLEASE
  • Peanut 3 Feb 08, 2008
    My camera Beeps 3 times but never shows a picture. Each time I press a botton it does nothing.
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Posted on Dec 08, 2007
  • agbq89inva Dec 08, 2007
    My camera (Samsung Digimax S700) had the same problem. The lens was stuck open. I would hit the power button and it would turn on briefly, beep 3 times and shut down. The lens would not retract and close.
    I put fresh batteries in and it still did the same thing.
    What fixed it was what another person said earlier. I gently twisted the lens and it seemed to "unstick". The next time I turned it on it stayed on. Also, when I turned it off, the lens retracted and closed.
    Hypothesis: There seems to be a shut down feature if the lens doesn't work freely. We ran the batteries down, so that may have something to do with the lens sticking in the open position.
    Also, we use the Ni-Cad 2500 mA. They hold a long charge and work well with the camera.
    Hope this helps. Blessings to you!
  • Samsung Master
  • 4,738 Answers
The following blog outlines some other repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
  • 3 Answers
You are probably using the wrong batteries. I had the same problem. In fact I posted a thing on here. Anyways, we started using Lithium batteries which are recomended for this type of camera, and I strongly suggest it, because we tried them and the work! I hope it works for you too! :-)
Posted on Dec 02, 2007
I HAD the exaxt same problem. i readjusted the lens with my hand and now it works!
Posted on Nov 24, 2007
We have just developed the very same problem with our digimax s700, it doesnt stay on long enough to look at memory or battery data and the screen doesnt come on anyway...when u switch it on the little green power light comes on it beeps three times and then switches off again
Posted on Jun 03, 2007
    Genius:
  • 2,985 Answers
Check the manual to sure that this type of error is not listed. Check that memory card is inserted correctly. If you can before it shuts off try the menu button and if successful- look for RESET. Do get onto the Samsung web site technical Support
Posted on Jun 02, 2007
  • 1 more comment
  • john ash
    john ash Jun 02, 2007
    Well it wont run with out a memory card thats for syre
    Can you test the memory card in another camera to check that it is viable or obtain[borrow] cnother card to check that it is not the card causing the faulting?
    Failing that take it back to the shop to see if they can checkit out for you.
  • john ash
    john ash Jun 03, 2007
    Internal memory!!
    How does the camera switch to the card when the internal memory is full do you have to switch manually or is it automatic?
    Consider this- if the internal memory is full then maybe what you are getting is shut down.Clear the internal memory.
    -------------------------o0o----------------
    How come your brother is using the camera if it wont work?
    Something you are not telling me here?
  • john ash
    this is going to be a repair shop job- unless you discover some reason for the beeps in the manual- check out the more comprehensive manual on the CD
SOURCE:
I have a samsung S500 and when I turn it on the lens doesn't open or extend and it will beep 3 times and shut off. I have tried new batteries and nothing works. I took it to a camera shop and they
Well, have you ever considered that the lenses MIGHT be defected? If it's true, you can send it back to the manufacturer, as long as it wasn't YOU who made it defected.
Another tip, is maybe the lens isn't made for that type of camera.
Lastly, the lens can just be broken, so you should carefully examine it, and see INSIDE of it, to make sure all of the parts are their. Hope this helps (:
Jun 11, 2012 | Samsung Digimax S500 Digital Camera
Digimax s500 cutting off
BAtteries draws down too quick...
Use 2500 mAh or better for longer life the higher the number...
eveready bunny is sometimes not in all their work
Jul 27, 2009 | Samsung Digimax S500 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
SAMSUNG, Gigimax S500, 5.1 MEGA PIXELS, SHUTS-OFF WHEN TURNED-ON
There appears to be no rhyme or reason to your query - I advise you to contact Samsung directly,
Sep 04, 2017 | Samsung Digimax S500 Digital Camera
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
When I try to turn on my camera (Samsung Digimax S500), it beeps 3 times.
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
Apr 20, 2008 | Samsung Cameras
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
HELP!
Use lithium batteries. I had a problem when our camera would turn on for a few seconds, beep 3 times, and then shut off. The best batteries, which are actually recomended for this camera is the lithium batteries. I strongly suggest them.
Nov 13, 2007 | Samsung Digimax S500 Digital Camera
Will not stay on
Lens motor stalled. Checkout the price of a repair at Samsung support
Sep 09, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
811 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
