Question about Intel D945GTP Motherboard
My video card will not work
We looked at the video cards memory and the pc says that it is not there but we look at the system and see that a large memory is there can you help me with this problem
  • 33 Answers
Could need to reinstall the driver.  Should be able to do a google search for the driver.
Posted on Jan 08, 2009
Which graphic card is suitable for my compaq presario sg1138il pc?
The type of graphics card you need depends upon the programs you are using.
For example if you only use your computer for simple wprd processing, e-mails etc. then you only need a low end graphics card.
If you have a high performance computer and you play graphics intensive video games that renders realistic images, then you need a high end graphics card and these cards will have large video RAM (memory).
There are a large range of graphics cards on the market, I suggest you Google search for graphics cards that matches your programs and application requirements.
If your model computer has an AGP expansion slot, then make sure the graphics cards are AGP cards.
Sep 03, 2010 | Compaq Computers & Internet
What is compatible with my emahcines w3050 in upgrading my video memory. What limits are on my machine?
HDMI? Oh, then you would be talking about a graphics card like this one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5071689&CatId=318
HIS Radeon HD4670 IceQ
1) AGP 8X graphics card
2) Has a VGA, DVI, and HDMI port
3) 1GB of GDDR3 ram memory
4) 128bit interface
5) 320 Stream Processors
6) Core Clock is 750MHz at maximum capability
7) Memory Clock is 1746MHZ at maximum capability
It doesn't matter that your computer system ram memory is DDR Sdram. The GDDR3 graphics ram memory operates independent of the system ram memory.
Information about graphics, graphics cards, and graphics card terminology,
A) http://www.brighthub.com/video-games/pc/articles/984.aspx
B) http://computer.howstuffworks.com/graphics-card.htm
Mar 20, 2010 | E-Machines W3050 PC Desktop
Memory card
Have you formatted memory card in phone before you started storing data on it? By formatting the memory card it will set up folders which the phone will look at to determine different types of data, i.e. photo folder holds photos, video folder holds mp4 &3gp, and music folder holds mp3 etc.
Then when your memory card is connected to your pc drag and drop data into correct folders and then phone should be able to recognise the different types of data. Hope that helps?
Only other thing I can think is that your memory card is too large to be recognised by your phone? It will only support upto and including 2gb Micro SD cards.
Apr 24, 2009 | LG KU990 Viewty
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more...
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Feb 19, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Need Help !! D865GBF / D865PERC Intel Motherboard No Pictures
While the system may be emitting a memory error beep code, that obviously is not the only issue here. If there is onboard video and it isn't working, try this:
1: Unplug system
2: Open case
3: Look for the CR2032 flat watch-style battery located on the motherboard, usually around where the front panel connections are
4: Remove this battery using a flathead screwdriver to push on the tiny 'hook' of metal holding it in. DO NOT PRY THE BATTERY OUT.
5: Let system sit for 10 seconds and put the battery back in.
6: Power the system back up
What this does is drain the system's memory completely. If it was perhaps set to use the AGP video card (which isn't installed, hence no video), this setting should be cleared and you should get onboard video.
Failing this, really, your only choice is a new motherboard, or to install an AGP card and see if it works. If you don't feel like hunting down a replacement board, I'd just order a cheap AGP card. If the AGP card works, use it. If not, then your motherboard is really pooched and you'll need a new one anyways.
About the memory beep issue:
You can google memtest86 and download that program. Burn it to a bootable CD and run the memory test; it should tell you if the memory is good or not.
hope that helps!
Jan 05, 2009 | E-Machines eMachines Desktop PC
I want to upgrade to a new video card
You can put new Video card accordingly. Just buy an good Video card which have inbuilt memory and that support your operating system. There are loads of Video card available in the market.
Dec 26, 2008 | Gateway GX7018E PC Desktop
Memory card
Take all the memory contents out to your computer as backup, format your memory to fat32 and put all the memory contents again to the memory from your computer. If not working try downloading the card system files from the card manufacturer site, these files are needed to run the card just like the operative system in your PC, if these files get corrupt or deleted the card wont work.
Aug 09, 2008 | Nintendo DS Lite Console
Memory card
Yes, it is likely that the larger memory card is slowing your camera down.
Jul 21, 2008 | Olympus MJU 400 Digital Camera
Intel D945GTP Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
