Question about HP Color LaserJet 2600n Printer
I need to cold start an hp 2605 dn to get my printer to work.
The printer doesn't print at all and everything is hooked up properly. a private Service and Support person told me to cold start it and after trying I don't see the prompts to do this. I was wondering how to reset the printer from the "cold start."
  • 1 more comment
  • james923 Jan 08, 2009
    Im sorry for the cunfusion. Its a new hp2605dn. . . i want to reset the factory defaults to get it to work. Or at least try this and seeting the defaults back was done by a cold start and holding down the "check" button and waiting for the cold start prompt. Or at least that's what I was told. I treid this and i didn't see the prompts. Now I don't know what to do
    I should also add that the printer says that its printing the document but nothing happens
  • Frank
    Frank May 11, 2010
    is this printer new or used?
    there is not such thing as a cold start. you can unlpug everything and press and hold the start button for 1 min and then conenct everything back, restart the printer.
    Genius:
  • 1,605 Answers
2605dn is a network printer. did you set it up as network printer or stand alone?
if it is stand alond , all you have to do is connect it to the parallel port on the back of the computer, or use USB.
if it is a network connect, then plese post back, I will try to help you on that.
Posted on Jan 08, 2009
    Scholar:
  • 101 Answers
To most of us "cold start" means disconnect the power cord from the device, wait a minute or so for any residual power to drain in the powersupply. I hope that is what they were meaning here. Then plug it in, power it up! If nothing happens verify the power source and the unit does not have a blown fuse. Another possible meaning is to reset the unit to factory defaults, but that would of course require the unit to power up. Good Luck.
  • Buddy Jaet Jan 08, 2009
Windows 8 doesn't print on network printer
Make sure you don't have the same printer installed more than once. If you do, that confuses the system and it confuses you. You might be printing to a printer that is offline if you have it installed more than once.
Click Start/Control Panel or Click Start/Settings/Control Panel. Look for Printers. Open it up and see if the same printer is listed more than once. If so, delete the extra printer.
If that's not the problem you have a driver issue.
Get online and got to www.google.com In the google search box type: "HP Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Printer drivers.
May 18, 2012 | Computers & Internet
My printer 2605 laserjet prints a black shadow on the letters in the vertical line of the document
calibrate the printer 5 times ur problem will be resolved if not then cold reset the printer.for cold reset switch on the printer & press the green button before counting the memory when all three lights glow at a time then release the button & select the cold reset option by up-down arrow then enter ur problem will be resolved..............
Jul 30, 2010 | HP Color LaserJet 2600n Printer
My black toner said it needed to be replaced, so I did. Now the printer will not work and says all other 3 colors must be replaced. Is there a way to reset this? Or if need be, can I just print in black?
try to reset the printer on factory setting /cold reset
off the printer then on before start counting the memeor press & hole the go button untill all lishta glow simualtaniously release the button you have to select the cold reset on lcd by the up/dn arrow then pres the go button it starts the cold reset if problem remain same pls replace all the tooners ur printer works fine .......................
Jul 02, 2010 | HP Color LaserJet 2600n Printer
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
HP2605 shows 50.7 erro
Sounds like a faulty sensor. Buy a can of compressed air blow it throughout the printer. Sometimes toner dust sits on the sensors giving a false reading. If after this you still get an error you're going to need a printer engineer!
Dec 15, 2009 | HP Laserjet 2605 Printer
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
My printer is printing colour red faintly, the toners are new and genuine. it also takes some times before it starts printing.
Sherry, in all probability it is the "scanner assembly" HP can fix this for $279 in the US using HP Express exchange 1 day ship, this was the result of their active chat. I am having the same problem and am going to dismantle the printer myself to see if I can't clean the scanner mirror myself. If you search the following words on google you will find some info, fading red tones laser jet 2605, one of the first results is a page on the HP site specifically on laserjet printers. I wish I had a quick fix that would help; however, a new cartridge won't help!
Feb 09, 2009 | HP Laserjet 2605 Printer
Computer can't find printer
Your using an Ethernet cable and your not on a network. You most likely need a USB cable, or connect the computer and printer together with a router. How are you accessing the internet from home?
Nov 19, 2008 | HP Laserjet 2605 Printer
HP Color LaserJet 2600n Printer Logo
1,300 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
