Question about Marc Refrigeration Marc Self Contained Double Duty MeatDeli Case 96inL
Sharper image meat thermometer model # mi 215 doesn't work.
I don't remember it ever working
I need to know if it has batteries that need to be replaced and where they are. I tried but couldn't figure it out, also instructions on how to use it.
Thank you
  • 4 Answers
I have this same thermometer (MI-215) and unfortunately no manual. I have not tried to change the batteries yet, BUT, you can try this, which is what I have done, which is to download the manual for the MI-220 from Amazon.com. It is the next later version of the thermometer/grill fork. They are very similar. If you go to Amazon's home page and type in Sharper Image Grill Fork it should bring it up in the search results. Click on it and when the page loads, then scroll down to where the link is for Product Manual. You can either print it out or save it in .pdf format to your hard drive. Hope that helps.
Posted on Feb 16, 2009
What are the benefits of using a cooking thermometer?
Using a cooking thermometer takes away the need to cut into a piece of meat or chicken to see if it's cooked. Also it reduces the risk of harmful bacteria that come with undercooked meats.
Feb 14, 2013 | Home
Will not blow heater hot when first started
I don't understand no cars have heat when first started. Lets try this engine cold take cap off radiator put in a thermometer like a meat thermometer it will read the temp of the water the antifreeze should be right to the top. Start the car and let it run when the upper radiator hose gets hot all of a sudden that is when your thermostat is starting to open it will read 180 to 195 on the thermometer it will fully open at 200 to 215 and the electric fan should be off till it is above 200. If the radiator hose feels like water is going through it right after it is started and the engine slowly warms up to about 100 to 120 and won't go above you have a bad thermostat replace it. If this helps please rate it thanks. If you have any questions just ask I will be watching the post
Dec 26, 2011 | 1994 Toyota Celica
1999 ford taurus is overheating. Head gaskets have been replaced and it takes awhile for the cooling fan to turn on. What else could be the problem?
Are you sure the head gaskets needed to be replaced was it to stop the leak? Go to an auto parts store leave a deposit and use the tool for free. One tool has a cap that fits on the cooling system and has a pump on top You pump the system up to 15 pounds and look around the engine and the radiator for leaks. This is what your repair shop should have done before they replaced head gaskets. Putt a meat thermometer in the radiator when it is cold start engine. Let run. Put hand on upper radiator hose when the thermostat is starting to open the hose will turn hot right away the thermometer will read 180 to 195 If the engine starts to over heat the thermostat is bad but if it opens the temp will slowly rise to 200 to 215 that will be fully open and around here the fan will turn on and cool the engine down( make sure the air is off or one fan will be on all the time) if fan comes on late replace temp sensor for radiator. If everything works the radiator is probably plugged
Dec 05, 2011 | 2001 Ford Taurus
Can you give clear instructions on to use the weber pocket thermometer.The instructions i got with it i find are not very clear;and could you tell me the proper temperature for all the various meats.Thank...
Here's the general rule of thumb for cooking temperatures for meats. Remember though, you cannot leave the thermometer inserted in the meats while cooking. It's only for Instant Read.Always insert it in the thickest part of the meat away from any bobes.
BEEF RARE 14=30 - 140F
Jul 30, 2011 | Weber-Stephen Products Weber Digital...
I have an Mi212 remote meat thermometer and it no longer gives me the temperture only 3 initials like KKK something like that which looks like a code.
I had the same problem with mine. As soon as I replaced all 4 batteries, hit the reset button on the probe unit, turned both off, turned the receiver unit on, then turned the probe unit on, it started working fine.
Jul 27, 2011 | Sharper Image Remote Cooking Oven Bbq...
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
How do I know if it is working?
WHERE CAN I DOWN-LOAD THE OWNERS MANUAL FOR Sharper Image/Ionic Breeze/s1830
Jun 22, 2010 | Sharper Image Ionic Breeze GP SI730 Air...
SHARPER IMAGE -- M1600 / M1601 Swivel world time clock .
Push the mode button until the top window says 'Alarm', push the up or down button to shut off the alarm, push the Set button to set it.
Mar 05, 2009 | Watches
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Marc Refrigeration Marc Self Contained Double Duty MeatDeli Case 96inL Logo
794 people viewed this question
Top Marc Refrigeration Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Marc Refrigeration Refrigerator Expert? Answer questions, earn points and help others
