Question about Kenmore 70088 Air Conditioner
Window to wall unit?
Hi there - I have a Kenmore window a/c unit, and we recently moved into a condo with through-the-wall units. Can I swap a through the wall unit with a window unit? Is there any special conversion/installation package I need to get? Thanks! Dana
    Sergeant:
  • 288 Answers
No, actually switching from window to wall is easier that vise versa. I don't know your can size versus the hole in the wall but you may have to enlarge it if its bigger or fill in the space with some wood trim on the outside and some molding or sheetrock on the inside. some insulation wont hurt either . the expandable foam is good for the wall space. Caulking for the cracks. pretty basic stuff. A good way to mount it is to slide the louvered can out and screw it to the wall, then its nice and secure. Unless its a very large and heavy unit, you shouldn't need any support struts on the bottom.
Posted on Dec 20, 2007
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
I have tried over a month to get someone to my home to fix my window unit. Bought Aug 11, 2010. Nobody will call me back. It was cooling when we turned it off this past winter and when we turned it on...
One thing you will find is most service companies dont work on window units anymore because there is no money to be made in it. These units are very disposable most repairs will exceed the cost of replacement most companies charge $85 to show up and time and material after that. Most people dont want to pay that much money for their window unit. Best advise contact the 1800 # on your kenmore paper work they might be able to help. Sorry for the bad news but most repair service call usually cost betwwen $180 - $250 window units arent much more.
May 31, 2011 | Kenmore 75050 Wall/Window Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Just bought a kenmore 10000 btu window a/c unit - need to install
You CAN put it on the 3rd floor as long as you make sure it's completely secure. One thing I do recommend is building (or buying) a window unit shelf that sits outside the window and the air conditioner sits on it for extra support. The shelf is secured by the window frame.
There are many "how-to" guides to building a window unit shelf all over the internet.
I hope this helps.
Aug 17, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Moved a/c to another window and wont work
Check your outlet wiring. The polarized outlet has a narrow slot and a wide slot, and a ground hole, of course. Anyways, the narrow slot should be hot. If you put a voltage tester lead into the narrow slot, and the other lead into the grounding hole, you should read line voltage if the grounding hole is grounded properly. If you test the wide slot to ground and get line voltage, you have reversed polarity and must swap (reverse) the lead wires in the outlet to correct the problem.
Jul 30, 2009 | Kenmore 6000 Wall/Window Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Sep 06, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Kenmore 70088 Air Conditioner Logo
159 people viewed this question
Top Kenmore Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Gil Shultz
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
