Question about Fujitsu 18C1 Air Conditioner
Wall unit emits a chemical smell when the unit is running
The unit is less than a year old and is being run daily. During the past month we noticed that when the unit is running there is a chemical smell coming from the unit
  • 70 Answers
Check the condensate pan clean out with vinegar water solution make sure you do not see any oil residue that would be a sign of a refrigerant leak let me know if you have further problems your manual should tell you how to get the cover off
Posted on Jan 08, 2009
Kenmore Dishwasher 665.1383 is about 4 years old. The past 2 months it has developed a strong plastic or chemical smell. The smell has tainted brand new glasses that then have the odor when they are...
that's not the full model number,there should be four more numbers.anyway does it have a heating element in the bottom of the tub,if so feel it with your hands,a piece of plastic could of hit it and is still melting when you run it,you can try using dishwasher magic,it's a bottle that you stick in the washer,the heat opens the bottle and it cleans the machine,also what kind of soap are you using?maybe try a new brand.also make sure the heater is in the metal holders,i've seen it knocked out and it will burn a hole through the tub.
Apr 09, 2011 | Dishwashers
The compressor will run at times, but the condenser fan doesn't start and the unit shuts off on either high pressure or the compressor overheats. Why doesn't the fan start with the compressor? The unit is...
IF UIT IS A YEAR OR LESS OLD YOU ARE BETTER OFF CONTACTING THE MANUFACTURER, SINCE THE UNIT HAS WARRANTY FOR PARTS AND LABOR DURING THE FIRST YEAR THEY WILL COVER ALLSO THE FREIGHT COST.
CALL THEM 858-566-7473
Mar 16, 2011 | Breezaire WKE 6000 Wine Cooler
Old baseboard heater smells like menthol
sorry, no solution. but. we recently moved into a 1940's apt. which has these older electric baseboard heaters and if we run them, they put off a menthol/chemical odor -- which sounds like the same thing you are experiencing (so will be very much interested in seeing if there is a solution).
if we either a) leave the heater running (even on low out in the living room) while we sleep or run it all day and don't air out the apartment, we both have serious achy joints the next morning and lots of stomach acid/irritation throughout the nite - also dry, red irritated eyes. apparently the cat has something going on as well -- he will get up throughout the night and walk thru the apt. yowling (not normal for him, only after we moved and started using the unit).
it took us a couple of weeks to identify what seemed to be causing the problem (the baseboard unit) and another week to do enough testing to determine that yep, you run that puppy, you're going to be real sorry that nite/next morning (and you won't sleep much because of the yowling cat). turn it off, no menthol/chemical smell. no yowling cat. no throat, stomach, eye irritation/gradoo, joint aches or sinus stuff going on that nite/next morning.
our solution? turn it off and leave it off. we're using a small metal cased ceramic disc heater instead (recommended on those multiple chemical sensitivity sights - figure if it's good enough for them it's good enough for us).
interesting info on EPA site re: appliances we don't think much about. one study re: air cleaners/ionizers, etc. - they did a random test of all kinds/price range/quality of air cleaners. they found **without exception** that all air cleaners/ionizers they tested put out "dangerous levels of chemicals" (their words). their recommendation, until further testing could be done is that if you want clean air... open a window.
it got me to thinking about this heater thing. and i wonder how many people are on medications for stomach issues (acid reflux, irritable bowel syndrome, etc.), sleep problems, joint aches, etc. that are caused by the appliances we run in our homes for air control.
i'll leave you with one other statistic that may be related to all of this: according to the CDC, 67% of the u.s. adult population is on at least 4 medications. when you look at that, you wonder, ok how many of us are on at least 2 medications (85+%?).
doctors usually don't ask you about what kind of devices you are running in your house and whether you notice a pattern of symptom abatement when you turn them off. they just give you whatever it takes to mask your discomfort.
just a thought.
Dec 10, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
I can herar water runnging inside the regierator.
You are probably hearing water running out of the unit during a defrost cycle. It runs inside a tube to the underneath of the refrigerator where it is collected in a pan and evaporated into the room by heat from the compressor fan.
Jun 28, 2009 | Whirlpool Refrigerators
Kitchenaid refrigerator smells.
hi feel sorry for u but if u have all this problems already... why don't u ask the company or store u bought this LEMON..... so replace it or get money back...otherwise go in contact with customer protection and complain to them,,,,,
hope u get a satisfactory answer.....
Mar 11, 2009 | Refrigerators
Plasma TV smell?
i had the same prob and thought it would burn off. It didn't after a month. Read the comments and tried the plug direct into wall socket plus i washed off the tv surface several times. Now no smell. Not sure which action cured the problem but i'm now happy. It was so bad i had to leave a window open and at times i would gag from the smell.
Jul 20, 2007 | LG 50PX5D 50 in. Plasma HDTV
Fujitsu 18C1 Air Conditioner Logo
530 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
