Question about Panasonic Lumix DMC-FZ7 Digital Camera
The flash does not work on my dmc-f27, why?
When setting the camera for flash and them taking a picture the flash does not work.
Check to see whether you've turned on the digital conversion for a wideangle or other lens. As I recall, that disables the flash. There may be a conflict between the flash and some of the other possible camera settings as well.
Posted on Feb 25, 2009
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
My panasonic camera DMC-F27 is showing "memory
Hi pblac11,
This could be a problem with the format of the memory card , or the memory card is not formatted as per the requirements of your camera.
I would give you a way out to try and see if it works , as I have been through this problem myself too.
Using a card reader device , connect your memory card to your computer and make sure it gets detected in your computer.
In case you are using windows xp , vista or windows 7 , you will find the removable drive relevant to your memory card being detected.
Now all you have to do is try and format the card in a mode that is different than the current one.
For e.g if your memory card has been formatted by NTFS file system , then try changing the format to the FAT32 file system.
and if it's FAT32 already , try formatting the card with the NTFS system and then try and insert the card in your camera after it has been formatted successfully.
The above solution has helped me , hope it helps you as well..:)
Your feed back would be appreciated.
Jun 21, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
I have a Panasonic DMC-TZ4 camera. I am on vacation and my settings got changed. I do not have the manuel with me. My flash won't work for indoor pictures and I do not know how to change the settings. Help
One of the buttons on the back has a lightning bolt icon. In picture taking mode, press the button and watch the screen....it will cycle through auto flash, red-eye flash, flash off, etc.
Oct 27, 2010 | Panasonic DMC-TZ4 Digital Camera
My flash bulb doesn't work, picture are dark
Do you have it turned off? Is there a picture of a lightning bolt with a line through it? If so, press the button with the lightning bolt until the screen shows a lightning bolt and an "a". Also, do you have the camera set on a scene mode such as night? The flash won't go off in some scene modes.
Jan 28, 2010 | Panasonic Lumix DMC-FX10 Digital Camera
Instruction manual
I have an FZ7K, here’s what I do:
#1. Set the mode dial on top of the camera to “A”.
#2. Set the aperture to the smallest f/number possible, f/2.8, f/3.2, f/3.3.
#3. Now take pictures standing as close to the subject as possible, (or zoom the lens).
For even better results, have the background farther away from your subject.
Aug 20, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
I have a Panasonic DMC-F27 digital camera using a SanDisk. I keep getting "disc error format yes or no". I don't want to lose my pictures, so should I select yes or no? Thank you
For sure if you select yes, you will lose your pictures. Formatting erases everything from your card and you cannot get them back.
Jun 27, 2008 | Panasonic Cameras
Instruction manual
When I put in a memory card with pictures that someone else took with their camera nothing shows up. Actually it seems like my camera freezes. Please help.
Dec 28, 2007 | Largan Chameleon XP Digital Camera
Panasonic DMC-FZ1 Flash still not working
If you have a lightning symbol followed by “A” in the upper left corner of display, try to change it to forced flash (only lightning symbol) or reduce iso settings because probably the camera “thinks” there’s sufficient light for the photo.
Oct 08, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
DMC-FX01 Flash Does Not Work
In what mode are you trying to take photos? The flash will not work in certain modes (see the manual), for example the night mode. Or you accidentialy turned on sequential/burst mode (this is mode where camera takes more pictures on one shutter button press). Flash cannot be used in this mode also. I don't have FX01, but on FZ8 the camera will show flash icon in red, but will take the picture anyway without flash being triggered. The second problems seems like enabled power-saving mode, but those 5 seconds are too short for this. But anyway you can check in SETUP menu the settings for power-save. Also maybe the flash is broken and camera noticed it... I don't think this could be a software problem. Either problem with the flash, but more probably just setting of wrong mode.
Jul 24, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
344 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
