Question about Toshiba Satellite A100-S8111TD Notebook
Missing wininet.dll no disk
Im having problems with my toshiba laptop it wont load my laptop all the way do to the error message missing wininet.dll reinstall might solve the problem but i dont have a disk cant afford it
  • FirstBlade
    FirstBlade May 11, 2010
    Do you get this error after Windows loads? If so try booting in safe mode if your OS supports that.
  • Sean Osborne
    Sean Osborne May 11, 2010
    What model name and number is your laptop?
  • 69 Answers
Probably u are trying to reinstall the same windows program that is damaged and is still in the cpu. find another windows disk and dowload this from "bios" (select the option "download from cd-rom") this will totally reset yr hard disk and all yr data and settings will be lost
Posted on Jan 08, 2009
I have toshiba satellite 2065cds, when started windows loads, then when logon/password screen show, error occurs, "missing msvcrt.dll.. how can i reload the msvcrt.dll file into windows without...
does your laptop have a cd drive and do u have a computer with a burner i can find you the msvcrt.dll and can walk you thru how to copy it into the right directory.
Mar 15, 2011 | Toshiba Satellite 2065CDS (PAS206U-S6CW8)...
How to repair missing wininet.dll?
If you see an error related to the wininet.dll file being deleted or missing, copy this file from the c:\windows\system32 directory of a working Win XP Pro
or Win Vista computer onto a flashdrive, then use the following procedure to copy it onto the failing system.
  1. At the boot screen (the first thing to appear at power-up), hit the F8 function key.
  2. Select 'Safe Mode with Command Prompt' and continue.
  3. In the command prompt window, type the letter of your flash drive, either d: or e: until the drive appears as e:> in the prompt window.
  4. Type 'dir' to see the wininet.dll file on that flashdrive.
  5. Once you see that file, type 'copy wininet.dll c:\windows\system32'.
  6. Unplug the flashdrive and reboot the failing PC.
Once you succeed in reviving the failed computer, go to c:\windows\system32 and right click on the wininet.dll file then copy and paste it to a save name (recommended name: wininet-copy.dll). This allows direct copy of that file back into wininet.dll if the problem reoccurs.
If you suspect an anitvirus engine or some other application deleted this file - and if it occurs again, make note of what was being performed, immediately before the failure mode. This will lead you to the offending program needing attention.
Good luck, hope this helps.
Aug 07, 2010 | IBM NetVista PC Desktop
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
I can't get into my folders, applications, etc.
The error message you are getting is a result of a trojan virus that embedds itself in WININET.DLL.
Two simplest solutions:
1. If there is nothing important on the laptop that isn't already backed up, use your Dell install disks to re-install the computer.
2. If you have important files on the drive which are NOT backed up. Take it to a pro, or buy a 2.5" Hard drive enclosure, put your drive in the caddy and connect it to another computer that has an up to date virus scanner. Scan the drive for viruses and allow the virus scanner to clean all virus' it finds.
When that's done copy the files you need to the other computer and then Restore the laptop as per step 1. When it's up and running again, install a good virus scanner, then copy the files back to it from the other PC.
Hope this helps,
Chris
May 14, 2009 | Dell Latitude D600 Notebook
PowerCinema for Toshiba error message
Here we go, just paste this site in your browser and download the dll. This should correct your problem:
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
http://www.driverskit.com/dll/msvcr71.dll/2373.html
Mar 07, 2009 | Computers & Internet
Tosiba laptop could not start not even with safe mode.
The error message refer to system files it cannot load dur to either corrupted or missing files.
You can try to do a repair with your Windows CD install disk and if this does not work you will need to reinstall Windows again together with any drivers that Windows didn't install and your programs.
Note you will lose you data in this process, hoped you backed up your files.
Mar 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
My laptop was turned of during an recovery point[system restore]
Try doing a system restore from a previous retore point. However, you will not be able to recover any files that were saved after that point.
If all else fails, you may have to reinstall the OS. The "wininet.dll" file may be from some software you installed at a later point..
May 15, 2008 | Computers & Internet
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
Apr 17, 2008 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Toshiba Satellite A100-S8111TD Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
