Question about Tools & Hardware - Others
Belt slipping I have a Ryobi 4x36 Belt/Disc Sander, Model BD4600. Even with a new belt, it slips or stops as soon as a piece of wood touches it. The yellow gear on the right changes the position of the belt, but does nothing to tighten it. I don't see any kind of adjustment to move the two rollers further apart to tighten the belt. There is a screw inside the lever mechanism that allows you to change the belt, but it doesn't seem to have any relationship to make the needed adjustment. The solution?
  • Anonymous May 09, 2009
    I have exactly same problem! Ryobi sander again. I had a cheapo Challenge one before this one and it worked like a donkey until I finally got it so hot the motor heat melted the plastic drive cogs for which I couldn't get spares. Subsequently paid twice as much for a supposedly superior brand (that I was told I could get spare parts for). Despite changing belts it soon starts slipping at the slightest pressure. Having read comments of possible causes, I can confirm I am not using excess (hardly any!) pressure, I have tried both deglazing belt rollers and inside of belt for good measure. The rollers simply need to be tensioned in my view but there doesn't appear to be a way to do this. I've looked at the manual and there is nothing about increasing tension beyond the set pre-tension lever. As far as I can tell the spring tension is still there.
    Any thoughts?
  • Thomas F. Schneider May 11, 2010
    Ryobi requires one to register for online support.
    All of the belt sanders that I have ever used have a spring mecanism to tighten the belt by a release lever that springs one of the wheels tightly against the belt.
    http://www.ryobitools.com/products
  • Tools & Hard... Master
  • 1,845 Answers
Because of build up heat the bearings and force will made that the center distance between the axle-bearings slowly comes to lie closer to each other, thats give by much belt sanders the same problem where bearings become dry and dirty it will tiny melt the bearings out of centerpoints of the housing if bought new measure and after a while measure the distances again and look remarkable and that will be the first problem if there is a medium pressure load by working maybe not but much people are working prolonged for that kind of tools .
Posted on Nov 16, 2016
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Posted on Jul 11, 2009
Ryobi belt and disc sander
It's only a month old. Take it back for a repair/replacement under warranty.
Jul 01, 2017 | Tools & Hardware - Others
HOW DO I REPLACE A TIMING BELT ON A 3" X 18" BELT SANDER
On the side of the sander there is a black triangle shaped cover with 3 screws holding it in place. Remove the screws and you will see the drive belt and 2 pullies or gears. The belt will be attached to the gears. Remove and replace the belt. Typically the belt is broken so the only thing you will need is to locate a new belt and slip in over the gears with the side with the teeth facing the gears. This keeps the belt from slipping. Reinstall the cover and you are ready to go back to work. The hardest part may be finding a supplier for the belt.
Aug 06, 2011 | Black & Decker BR300 3''x18'' Belt Sander
My Hitachi Belt sander SB75 the sanding belt moves off rollers as soon as applied to work piece how do I stop this happening?
There is a belt adjustment know on the side of the sander. Turn the adjustment know back and forth while the sander is running until it centers itself.
Jan 01, 2011 | Hitachi 3 In X 21 In Belt Sander, 2 Speed,...
How do you replace the drive belt on a ryobi type be321
I tried the model number and can't find it on their site, but if this is a belt sander or planer you can "roll" the new belt in place without loosening anything. If this is another tool let me know and please give me all the information (tool type) and I will check further.
Aug 23, 2009 | Ryobi Tools & Hardware - Others
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Jan 08, 2009 | Tools & Hardware - Others
Wood working sander?
belt because it work realy good use ing the circle scraches the wood and the beld dos not
Sep 28, 2008 | Milwaukee Tool Milwaukee 6125 Sander Ro 5...
Tools & Hardware - Others Logo
814 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
