Question about Sharp AR-M205 Copier
Ricoh af 220
CODE 320
    President:
  • Sharp Master
  • 990 Answers
Hello sir; that's laser motor problem, we can reset it, the procedure as follow;
1, press "clear modes" key .
2, enter"107".
3, hold down "clear/stop" key until SP modes come up.
4, turn off power and on again (main power switch)
If doesn't work , then you have to replace motor.
Posted on Jan 08, 2009
How to remove error code sc 220 in ricoh 4000 copier?
SC 220 - The Laser Diode Unit has failed
[Action]
Replace the Laser Diode Unit. Part Number B2471859.
Apr 29, 2017 | Ricoh Office Equipment & Supplies
How to clear error sc392 on ricoh aficio 270/220 photocopier
A few things to look for is make sure the developer roller and drum are actually turning (missing gear, teeth, etc...). Are any obstuctions blocking the developer from brushing the drum (I place paper between the drum and developer so I don't scratch the drum during *ssembly, if I forget to remove it - code). And make sure the connectors are secure.
It's not enough that we do our best; sometimes we have to do what's required.
or
https://www.google.com.af/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCIQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DvPe5fL_erZs&ei=jSWMVNb3L8jOygOjhYAg&usg=AFQjCNGPjBajIAh-ZNVxMbICi6EYxdN3zQ&sig2=4OZiTxo5eatVb3bXAD_6Zg
search the above link and watch the video
Dec 13, 2014 | Ricoh Aficio 220 270 Drum 60 000 Yield...
What will I do to Ricoh Aficio MP 3350B with an error code of SC220?
Ricoh Copier Error Code SC 220 is Laser Sync Detect problem. Check your manual and there is a fix for this in the menu.
Sep 30, 2014 | Ricoh Aficio MP3350
Error code sc 650
Ricoh AF 3025 error code SC650 is wat problem?
Jan 03, 2012 | Ricoh Aficio 3025 All-In-One Laser Printer
Sir machine code 320
this is an laser sync error usually requires new polygon/scanner motor part No B1211876 or may be B2591876 for US> you could try laser sync in service mode go to drum section and you will find laser sync there
Hope this helps
May 11, 2010 | Ricoh Aficio 250 Copier
My af 220 still got toner sign on after i add new toner
Is the toner cart you put in a third party? If so mite require OEM cart only
Apr 03, 2010 | Ricoh Aficio 250 Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Oct 30, 2008 | Ricoh Aficio 250 Copier
Ricoh AF-2020 SD problem
how can i get drivers fore this printer
Aug 23, 2008 | Ricoh Aficio 2020 All-In-One Laser Printer
Sharp AR-M205 Copier Logo
158 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
