Question about Lexmark Wheelwriter 15 Series II Typewriter
Carraige moves to middle and will go no further.
I have cleared out tabs and tried to express to right. No luck, it just stays in the middle and will return to the left but that is all. Prior to this I had a problem with the Correction ribbon. Now the mechanism that moves the tape does not move. Also, the keys don't engage the correction ribbon. I am sure that I probably need a good professional cleaning but I can't find anyone locally who works on these. Please help.
  • 4 Answers
Hello kstockman:
I am in Franklin, TN, too. Nashville Office Machine will clean, oil, and check Selectrics for $81.50. If the job doesn't use that much deposit, but parts are needed for repairs, they will apply money from the deposit toward the cost of parts. They have an enormous stock of parts for Selectrics, which they bought when the manufacture of IBM typewriter parts was discontinued. I am sorry, but I can't remember where they are located, but their phone number is 615-321-2679. They will also take the cover off and look at the typewriter briefly when you take it in, and can determine in a moment if they can fix it, and won't charge you the deposit or do any work, if it is obvious that they can't. They are very honest and reputable, and you can count on what they say. I drive all the way up from Columbia to have them work on my Selectric. They were recommended to me by a retired corporate secretary who used them for over 20 years and recommends them highly.
Posted on Feb 12, 2010
  • 328 Answers
Sounds like Auto return is activated. Try holding the code key down while pressing the letter R key.
Posted on Jan 12, 2009
  • Lexmark Master
  • 3,594 Answers
If you can ship it bto us i'm sure we can repair it.
DickyO
Cleveland Business Machines
2327 St. Clair Ave.
Cleveland, Ohio 44114
216-241-0027
Posted on Jan 09, 2009
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
My royal typewriter i just purchased on line its from the 50s and is blue has a carraige return problem. the carraige always stays to the left so you can not type you push it back and it just flys right...
The starwheel/escapement is probably gummed up. If you look from the bottom, you should see a "star" shaped part. Carefully spray a light lub around the area and move the carriage back and forth to free it. It may take several attempts.
Dec 20, 2010 | Royal Office Equipment & Supplies
Blocks puzzle # 57 in Nintendo DS 50 Classic Games impossible?
  1. Top Icon right (3 moves)
  2. Left Icon left (1 move)
  3. Sedond Left Icon left (1 move) clears 2 Icons
  4. Left Icon right (1 move) clears 3 Icons
  5. Top Left Icon left (2 moves) ends up on bottom
  6. Middle row Second Icon left (2 moves)
  7. Middle row Third Icon left (2 moves) clears 2 Icons
  8. Middle row Second Icon right (1 move) ends up on bottom
  9. Middle row Right Icon left (4 moves) clears 3 Icons
  10. Top Icon left (1 move) clears 2 Icons
  11. The Rest Is EASY!! (2 moves) clears 4 Icons
Jan 24, 2010 | Nintendo DS Lite
How to clear tabs on a Swintec 8016.
To get to tab clear try the tab set key with the code key or the shift key.
DickyO
Sep 18, 2009 | Swintec 7040 Typewriter
I have a swintec 2600 i cannot get it to clear out the tabs and i need to type beyound were the tab is
You must mean the margins. To move the right margin further to the right. Move the carriage to the right margin then depress the mar release key then space over further to the right to a new position and depress the right margin key. You should here a beep. If you just want to type further to the right of the margin, when it stops typing, simply depress the mar release key and continue typing.
Jul 21, 2009 | Office Equipment & Supplies
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Carriage release
try jiggling the carraige around a bit and then try using that lever thats on the right side of the carraige. you might even try both at once to see what frees it up. i had the same problem and it worked for me. That's the right tab, it may be in a jammed position so it wont open properly.
Apr 26, 2007 | Olivetti Lettera 25 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
