Question about Desa International White Wireless Plug In Door Chime
Door button works intermittently
The door button works intermittently and is position sensitive.  Works horizontal but not vertical. Seems to have a short.  Where can I get a new one.
SL-6164-RX FCC IDBJ4-61WDB64RX
  • 1 more comment
  • palmer_rowe Jan 08, 2009
    I have two of the same model wireless chimes which are not new.  Single button at the door activates both when it works.  Thought the battery was dead.  Changed battery.  Works when I hold the button in my hand and maybe once when I snap it onto the wall.  Found that while holding it the button will not work in the vertical position.  If I hold the button down and rotate to horizontal, it works.  Cannot mount it horizontal at my front door.  Need a fix or a new button.
  • Anonymous Apr 10, 2009
    Same problem.
  • dragon_rag27
    dragon_rag27 May 11, 2010
    do you mean a new doorbell?
2 Suggested Answers
  • 93 Answers
SOURCE: I NEED A PUSH BUTTON
you may wana contact the creator of this object
Posted on May 30, 2011
Wing mirrors will not adjust
Wing mirrors have a certain range of electrical adjustment. Manual adjustment by pushing with fingers can make electrical adjustment inoperative. The solution is to make finger adjustment to get back to the electrical range.
May 22, 2016 | Cars & Trucks
The game receiver door are jamming and i can not
do you mean the DVD tray?
try it in horizontal positions and vertical positions.
I had an 360 at one time that would not open the tray if it was in the vertical position.
Apr 07, 2010 | Microsoft Xbox 360 Console
How do you find the connection point for the horizontal rod that goes from the inside door handle to the vertical rod (with plastic knob at the top of it) that locks/unlocks the door? The car is a 1998...
The horizontal rod doesn't actually connect to the vertical rod. The horizontal rod connects to the door latch mechanism. The vertical rod also connects to the door latch, but at a different location. If as I'm guessing the horizontal rod has become dis-connected, it's probably because either the connector broke or fell off. If you need any further clarification, please leave a comment and I will try to help.
Jan 15, 2010 | 1998 Toyota Corolla
2000 Buick Lesbre - Intermittant electrical: Door
THE PROBLEM SOUNDS LIKE LOOSE WIRING CONECTIONS IN THE DRIVERS DOOR , BEST THING TO DO IS HAVE A LOOK OPEN UP DOOR PANEL AND CHECK ALL CONECTIONS, GOOD LUCK
Oct 22, 2009 | 2000 Buick LeSabre
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Apr 06, 2017 | 2003 GMC Yukon XL
The installer says the inside bolt control will be vertical in locked position on some doors and horixontal if the door swings the other way. I can't believe Taymor makes locks for only one instance ie....
A properly installed deadbolt will have the thumb turn mechanism in the horizontal position when locked and vertical position when unlocked... regardless of which way the door swings!
Your installer has it sandwiched improperly and it needs to be taken apart and the tongue inside needs to be correctly aligned.
Sep 01, 2009 | Kwikset Professional Door Lock...
Track ball does not allow east scrolling; it only allows west, north, or south scrolling
Try to change the horizontal sensitivity and vertical sensitivity of the trackball to 100%,to do this follow the below mentioned steps
1)press menu
2)select option icon
3)scroll down and select screen/keyboard option
4)select horizontal sensitivity and change it to 100%
5) select vertical sensitivity and change to 100%
6) press menu button and select save
May 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
Electric Mirrors do not work (Drivers & Passengers)
There are two power wires to the DDM - drivers door module .Both are orange ,one is powered by a fuse DDM fuse 15amp . in the left I/P fuse block , plus LT DOORS 25amp circuit breaker .
Do you know what DTC'S are ? Diagnostic trouble codes
DTC B1544, B1600, or B1605
DTC B1580, B1590, B1610, or B1620
• If DTC B1580 is set by itself, the left horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1590 is set by itself, the left vertical position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1610 is set by itself, the right horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1620 is set by itself, the right vertical position sensor signal circuit maybe open, shorted to ground or battery.
• If DTCs B1580 and B1590 are both set, the left 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
• If DTCs B1610 and B1620 are both set, the right 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
Need a factory scan tool to test !
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Driver Door Module (DDM) and Passenger Door Module (PDM) data lists.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
0.50-4.75 V.
Your best bet , take it to a GMC , Chevy , buick or cadillac dealer
Apr 16, 2017 | 2003 GMC Sierra 2500HD
Scroll ring intermittent / non functioal
I have a similar symptom, that is, apparent loss of scroll ring functionality as homercles1 noted, but in fact the scroll ring functionality gets toggled between horizontal scrolling and vertical scrolling as Rithas has noted. A window that is not wide enough to require horizontal scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in horizontal scroll mode. Likewise, a window that is not tall enough to require vertical scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in vertical scroll mode.
Solution that worked for me:
My upper right-hand button is defined as "Allow Horizontal Scroll" and by clicking this button, the scroll ring function toggles between horizontal and vertical scrolling. In fact, what can appear to be a nonfunctional scroll ring in some windows is very useful when moving around in large windows.
Hope this comment will be useful to you.
Nov 20, 2007 | Kensington K64325 Trackball
KDC-MP919 No display
You probably have a break in the flexible ribbon cable that goes between the flip face and the mother board. Try partstore.com for a replacement cable.
May 24, 2007 | Kenwood KDC-MP919 CD Player
Desa International White Wireless Plug In Door Chime Logo
162 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Steven R
Julian Pearson
Level 1 Expert
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
