Question about Uniden Cordless Phone
Tru8885-2 5.8Ghz no transmit/receive only
Have 3 muti-phone set up. My other 2 phones work fine. Can I reset or re-register (problem handset) to correct this problem??
I can hear voice on the line but can't be heard?
Thanks for Your Time, Bob Williams
  • 9 more comments
  • bobondrake Jan 13, 2009
    Summary of Question : no transmission/reception only/no dial tone when speaker button is pressed
    Question :
    I tried re-registering,reseting,checked mute button. Nothing helps.
    I can hear caller but caller cannot hear me. Is is time to by another hand set or can this problem be resolved.
    Updated 01/12/2009 06:47 PM:
    Also disconnected battery and recharged for 20 hours before reset and re-register.
    Just in case, could you please tell me what the replacement model number would be for tru8885-2?
    thanks bob w.
    Question :
    thanks bob w.
    So where would I find out who to contact to repair a speaker problem????????
    Question :
    thanks bob w.
    I removed battery when I reset emprom and re-registered the hand set. This didn't help either.
    my two other phones work on same cable, so how could cable be bad. I don't understand trying other socket. Could you define other socket please?
    what current model hand set would replace /or be compatible with my tru8885-2?
    it's 4 years old. the same age as the other to that work. They were purchased as a 3 muti set in 2005
    already tried factory reset. didn't work
    Is there any way to get this hand set repaired or would it be less expensive to just purchase another hand set?
    this solution has nothing to do with my problem.
    below is my original problem:
    Question :
    very disappointed in your service
    Sergeant:
  • 221 Answers
    Genius:
  • 1,239 Answers
No sound on the base unit speaker during call monitoringor message playback. Cannot access remote call-infeatures from another touch-tone phone.
If you still have a problem.
Suggestion ·
Adjust the speaker volume on the base unit.
Make sure you're using the correct PIN code.
Make sure that the touch-tone phone you're using can transmit the
tone for at least two seconds.
If it cannot, you may have to use
another phone to access your messages.·
Call customer hotline at 1-800-297-1023.
Posted on Jan 13, 2009
  • 15,935 Answers
HERE is the link to the manual for your unit.
Your model can handle up to 10 additional handsets.
De-register the Handset (Handset only)
Deregister the handset's ID from the main base unit or the base ID from the
handset. Use this option, for example, when you change the digital security code
(see page 74).
1) In standby mode, select Deregister HS in the menu and
press the OK soft key. D e r e g i s t e r H S ? appears.
2) Press volume up/down to select Y e s and then the OK
soft key.
When de-registration is complete you will hear a confirmation tone, and
D e r e g i s t r a t i o n C o m p l e t e appears.
3) After de-registering the handset, place the handset to the base to register.
Finding a replacement on eBay would be cheaper than repairing.
  • blueextc3221
    blueextc3221 Jan 13, 2009
    the tcx800 is the unit you are looking for.
    CLICK HERE to take you to an auction that is $29.00
    or HERE for one that is $.25!!
    Good Luck!!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, an extra handset for the Uniden TRU8885-2 is still available in the market. Pls try here or here.
Should you still prefer a completely new system, most big name brands with their latest models would serve the purpose. For technical reasons, suggestions would be with those models with the antennas exposed. Some comparable if not better models are:
to name a few.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 13, 2009
    Appreciate the postback. To your query:
    • "Is there any way to get this hand set repaired" - in most instances repairs is possible. The question is the repair cost and the down time. Often in your country, repairs are done by board replacement rather than component level. Board replacement would cost more and possibly challenging in purchasing a replacement board. In terms of repair/service fees, board replacement type of repair should not cost that much but component level would require more manhours (and therefore be expensive comparatively);
    • "would it be less expensive to just purchase another hand set" - yes.
    Top Expert:
  • Uniden Master
  • 77,194 Answers
The problem is the handset, u can replace just the one in most cases but it appears the your set is to old, there are a number of sets that use 5.8 Ghz, here is a link to these set at the Uniden web site, also u can get customer support at this website.
    Sniper:
  • 59 Answers
Hi if you bought it not to long ago then i would try to take it back because it could just be defective
    Guru:
  • 449 Answers
My advice is to get another phone the speaker is ded and to replace it to me it's not worth it, but yet again it's only my advice good luck Bob.
  • Uniden Master
  • 19,396 Answers
RE: " no transmission/reception only/no dial tone "
That is not a setting problem.
If you have broadband, use the broadband filter, or replace it.
Test the phone on a different socket, and test a different phone cable.
If it is none of the above, then it is a broken contact or a short on the mic/speakers lines, and the phone must be taken apart to fix the problem.
test cables and socket first.
    Genius:
  • 1,913 Answers
Remove batery from it then reset factory defaults setings then check .
    Sergeant:
  • 431 Answers
Try replacing the speaker
  • nematics
    nematics Jan 13, 2009
    try factory restore settings
    Sergeant:
  • 378 Answers
The step by step procedure to re-register
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Hope this helps
Posted on Jan 08, 2009
    Sergeant:
    Scholar:
  • 199 Answers
May be the speaker problem in your hand set needs reparing.
  • 6,487 Answers
Yes the first thing that you need to do here is to reset and re-register the non working hand set to your base phone and that will correct the problem,,,,
  • Mark Gil
    Mark Gil Jan 13, 2009
    If there's a service center near you i suggest you take it there and have the unit check and hopefully they can still fix it, because there's a big chance that the unit already needs a replacement...
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
Phone screen says "out of range" when it is within 3 feet of the charger.
The handset may have somehow become de-registered from the base. Try and re-register the handset. If it is stil saying it is out of range, make sure you are not too far from the main base, as a secondary charge dock does not transmit or receive any signals.
Jun 27, 2012 | Uniden Cordless Phone
One of my cordless phones says not registered. How do I fix that? Also, another phone says check battery. Where can I get another battery? Warranty?
Put the non-registered handset in the master base unit. Unplug the base unit for about 10 seconds and plug it back in. Wait for a message to change on the handset and press and hold the handset locator button for 4 seconds. This will re-register the handset. Do not remove the handset from the base while performing the above steps. Good Luck!
Nov 09, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
To deregister ALL handsets:
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
IF deregistering does not work .. you will need to reset the entire system
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
You will need to set the time and date again after resetting the entire system.
Mar 11, 2008 | Lands Phones
VT2461 ADDITIONAL HANDSET PROBLEM
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
Dec 12, 2007 | Vtech VT 2461 Cordless Phone
Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Apr 28, 2007 | Uniden DCT648-3 Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
