Printer is frozen.
Printer screen says it is shutting down, but seems frozen. We did not try to shut the printer down. When I try to turn off the printer with the on/off button, nothing happens.
  • 89 Answers
The simple fix is to just unplug it this will not cause any harm to it and it should fix this problem to you it happens all the time to myne
Posted on Jan 08, 2009
  • ianjcavanagh
    ianjcavanagh Jan 08, 2013
    Tried that but nothing hapens.
How can i fix my C6180 HP photosmart computer with msg of improper shutdown from wall switch
Try what they call a hard boot. In other words completely power down ththe printer by either removing the power cord or shutting down via the power button. If this does not work try to enter the menu and clear the arror code manually. Hope this helps.
Sep 08, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart PremiumC 309g-m started a day ago will not print anything even test page. Message says load paper into photo tray. Nothing obvious seems to work, shutting down printer and restarting,...
Unplug the power from the printer.
Press the # key and the 6 at the same time and hold them down
connect the power while continuing to hold down these keys
wait for a message about a semi-nvm reset or something like that to appear on the screen, and then release the buttons. If the unit shuts down while you are pressing the buttons, release them, and press power just long enough to turn the unit on.
If the printer does not react normally after this, post a reply here.
Feb 24, 2011 | HP Photosmart Premium C309A All-In-One...
Deleting paused and frozen there. Cannot use the
it seems you might need to rest teh PC..
Once you have done that and assuming you are running windows pls do the following (while the printer is OFF)
1. Go to "Start", "Run"
2. Type: CMD
3. press "Enter"
(now you should be in a DOS terminal window)
4. type: net stop spooler
press "enter"
5. type: net start spooler
press "enter"
6. type: exit
press enter
Turn on the printer...you should be clear now :)
Cheers,
Ed
(If this works for you, please grade this response)
Nov 06, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Won't shut down, won't finish boot - no functionability
I have had a similar problem since I bought this printer. When I make a copy or scan a document, the printer refuses to print anything else directly from the computer. If I turn offf the printer, I get the "printer is shuttting down" message in the display, however it never shuts down ( I've even left it overnight!) I have to pull the power plug out and wait ~30 seconds and then plug it back in to restore functionality in the print mode. I get some kind of nag screen at start up telling me that I didn't shut it down properly but I have just learned to ignore that. This problem is so consistant that I don't even try to print after making copies without unpluging the main power plug. Another issue you will probably run into is if you install Service Pack 3 on Win XP all your documents will print out in mirror image. HP's lame fix for this is to have you make custom settings in the print manager to remove the mirroring mode from the settings!! I am just about ready to change brands after being a faithful HP customer for over 25 years. They seem to have no interest in fixing known software issues anymore, as their push is to get new devices in the pipeline as soon as possible.
Good Luck
Tony
Oct 04, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Ink system failure, and printer turns itself back on..
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plug the power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Sep 29, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer Error Message after changing the cartridges
I'm not even pulling up any info on that error msg.
Where are you reading the error msg from, within Windows? Or from the printer itself?
Oct 23, 2007 | HP PSC 2355 All-In-One InkJet Printer
119 people viewed this question
jasbo
jasbo
