Question about Samsung Digimax A402 Digital Camera
Screen appears faulty
When i turn the power on, the screen is black and white, it appears broken but the screen is intact. I cant get any of the buttons to work, I have changed the batteries and also the memory card
    Genius:
  • 2,985 Answers
With switched on try pressing the camera casing around the edges of the screen. This may be a loose connector and squeezing the camera casing may rectify it - then may perhaps it will not. Try the menu button If it comes up look for the Reset function. Carefully look in the manual in case there is an error correction method. Failing all that Get onto the Samsung web site Technical Help.
Posted on Jun 02, 2007
Broken cracked black screen just under the top, can I get my photos?
Have you ensured that they are not synced to the cloud? Are they saved to the SD Card? Remove the SD Card and insert it in another phone to see if your pictures are there.
Mark
Motorola Support
Aug 24, 2014 | Motorola Mobility Droid RAZR HD
Black screen faulty contact
Check the connectors and wire loom that feeds the screen for bad connections or a broken wire.
May 25, 2014 | Fujitsu AMILO PC Laptops
Dropped iphone on ground in club and picked it up straight away. the screen is still completely intact and there is definitely no water damage. the screen froze for a few minutes before turning into a...
PRESS THE POWER BUTTON AND HOME BUTTON FOR 10 SECONDS EXACTLY AT THE SAME TIME. THEN RELEASE YOUR FINGER FROM THE POWER BUTTON WHILE STILL PRESSING THE HOME BUTTON FOR ANOTHER 10 SECONDS
Sep 19, 2013 | Apple iPhone 4S
Have a 50 inch vizio when u turn it on the lite in front turns white but no pic black screen any ideas
you will need to check your power supply!
All televisions wich have tese problems with starting faulty and screen staying black have power issues!
Apr 05, 2013 | Vizio L32 32 in. LCD HDTV
White Vertical strip appearing on AOC L32W861 32 inch LCD HDTV screen
hello, there could a few reason why this as happened 1 there could be faulty capacitor in the power supply 2 there could be faulty ribbon cable and 3 the t con board could be faulty hope this helps
regardsshaun
May 12, 2012 | Televison & Video
Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Aug 18, 2008 | Black & Decker 19" Electric Lawnhog...
White Sreen
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
Best of luck
May 26, 2008 | Kodak EasyShare C513 Digital Camera
LG cell phone
hi there
hav your phone serviced. that has an issue internal. they might have to replace some chips for that. youve checked the battery and still does the same thing.
hope this helps.
fixya!
Jan 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Samsung Digimax A402 Digital Camera Logo
37 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
