Question about Dell Inspiron 6000 Notebook
Driver for processor?
After reformatting my hardrive I know that there are a ton of drivers I have to install. I think I have installed most of them but my computer is running extremely slow....slower than before i formatted it....
Do i have to install a driver for my RAM or my processor?
What else could be causing it to be so slow?
  • mirage24 Jan 08, 2009
    I installed Windows XP Professional
    and before it was Windows XP Media Center
    I have a 1.6Ghz processor and 1gb ram so i don't know what is wrong....
    President:
  • Dell Master
  • 1,314 Answers
No, you do not need a driver for your memory or cpu. Try running a hard drive check on it. It could be in the process of failing. What happens is as the computer is reading and writing information, it comes upon bad sectors of the hard drive. When this happens, the computer continues several tries to write and if it continues to fail, the hd will mark the block(s) bad and attempt to write somewhere else. This slows your computer down a w hole lot because the hd is attempting to do other things whilst you are waiting. Good luck and please don't forget to give this solution a fixya rating. Thanks! :c)
Posted on Jan 08, 2009
    Scholar:
  • 111 Answers
Hell there,
Assure you have installed the chipset drivers for your laptop along with the latest firmware update for the hard drive you have installed which Dell has tagged as urgent.
All the drivers for that model can be found by following this link
Anymore questions just add a comment under your initial messege I will be glad to assist
    Genius:
  • 1,605 Answers
What operting system did you install? and what was it before you formted the hard drive?
the computer should be runing good without all of the extra.
  • Frank
    Frank Jan 08, 2009
    check the memories, made sure it is minimum or better.
    Windows Xp should run better than Mdia Center.
  • Frank
    Frank Jan 09, 2009
    Suggestion:
    copy all of the devices driver on to a CD. reformat and reinstall the operating system.
    sometime the installation files for operating system can be fragmented. you can do a hard drive defrag for the hard drive. it will help but not a lot. it is better start fresh.
    defreg the hard drive after each installation, so that all program files are in close appproximaty to each other.
    I have running to problem like that before, I don't know what the cause is. but reformat and reinstall fix the problem. I guest, the first installation scatter the files. If you look at the hard drive after the installion of operating system, you can see the files are not exactly packed.
Eee pc 900hd hard disk change. reformatted it succesfully but the drive d doesn't show off. and modem drivers cant install... help pls.
Hello Sir,
Check whether the drive D exists in your hardrive by going to disk management from the start menu. If you dont have the drive D, better create one and then try again. Let me know if its getting solved sir.
Aug 10, 2010 | ASUS Eee PC 900HD Netbook
My friend left his OPERATING SYSTEM disk at my house and when my computer got sick I Formatted MY Hard drive with his disk!!Being that he also had a Gateway (not the exact same model and 3 years older)with...
I think the problem lies with your dual core processor. Under Windows XP, these processors need to have the correct drivers installed to fully take advantage of the fact that they have 2 cores.
Try downloading and installing these drivers from the AMD website:
Dual core optimizer Processor driver
As always, back-up your important data, and preferrably create a restore point before going through with driver updates.
The radical choice is, obviously, to reformat using your own disk, as this should install correct drivers for all your hardware.
Dec 10, 2009 | Gateway GT5220 PC Desktop
From vista to xp
To change to XP, you have to reformat the hard drive and start from scratch, there is no other way to go backwards.
Nov 04, 2009 | Compaq Computers & Internet
No sound on my computer
Control Panel - System - Device Manager - Sound adapter
instal driver. Go to manufacturers website to find the correct sound driver. You do not need a CD driver, just a sound card driver.
Feb 15, 2009 | AMD SEMPRON 2500 Processor - OEM (AMD2500)
I hav to install sound driver in my p 4 sys.having processor 4.3g
know the manufacturer.if you know you to its web site,so that can be downloadle
Feb 07, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Sound driver
when you install linux then default install sound driver if you dont't select music option then you one packet install name is sound-juicer-2.16.0.3.el5.i386.rpm
Jan 08, 2009 | Computers & Internet
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Problem installing my webcam
Hey guy, Why dont you just go ton the manufacturer website and look for them, if not just go to a driverdownload, they have just about everything there.
Jul 09, 2008 | Computers & Internet
No sound device
I need to know the brand of the motherboard and its model/code number or model... then i'll know what sound driver is appropriate to your computer...
I'll wait.
Feb 02, 2008 | Intel Pentium 4 3GHz 512/800 CPU processor...
Dell Inspiron 6000 Notebook Logo
Alun Cox
