Question about HP OfficeJet 7410 All-In-One InkJet Printer
On/Off switsch does not work
HP Officejet 7410 All-In One. I could not turn the unit off using the switch so I unplugged it. Now I can't turn it back on. How do get it to turn back on. Is there some way to remove the contorl panel without losing all the buttons. If necessary I could just twist the switch wires together.
  • 2,071 Answers
It's better you open the printer and replaced the defected power switch with identical rating,so its works .When you going to open the printer put a marker each cover you have taken out and a labeled the wires in order when you going to closed it cannot be interchange.Desmantling now a device new to you its not hard now,becaused if you have a cellphone with video camera,you take a video or camera each time when dismantling one by one or piece by piece ,with the aid of marker dismantling made be easy..
Hope it may help you;
Regards;
VOTIT
Posted on Jan 08, 2009
  • HP Master
  • 13,433 Answers
Hp recommends if the product stops working properly and its still under the warranty, its suggested to send it to hp repair.
A service manual on the product would be great, but the price is very high
http://www.partshere.com/online/detail.asp?partno=Q5564A-manual
You will have to take the panel apart and inspect the power button, you may need to take the whole printer apart.
the problem may also be in the powersupply but thats unlikely since it worked fine before unplug.
I don't own the above service manual so my advice is limited in this case.
    Top Expert:
  • HP Master
  • 79,847 Answers
All the switch does is create a momentary connection that triggers a circuit board controller to shut off the printer, u will need to replace the circuit board which is in most case's is more costly than a new printer
    Scholar:
  • 100 Answers
No dont do that, just turn it off then unplug power cable. open it up by taking out all screws from the top cover where the power button is. when you get to the power button, see if its broken or loose or whatever and fix it by gluing it together if its broken or simply putting it back in place if its loose.
please dont forget to rate my solutioin :) thanks
    Sergeant:
    Novelist:
  • 326 Answers
It might also possible that the power cord of the printer is faulty.just replace the power cord and check out first before doing any thing technicall.and if the case of printer not getting power it can be a short circuit.
    President:
  • 2,110 Answers
Use these steps to resolve the issue. It might not be necessary to complete each step to fix the issue. Step one: Determine if the product uses a power cable or a power module as the power supply If the power supply is a cable with electrical connections at each end, the product uses a power cable. Figure 1: Power cable On/Off switsch does not work - c00057913.jpgIf the power supply is a cable connected to a module or box, the product uses a power module. Figure 2: Power module c00745315.gif
NOTE: The power module might have a permanently attached power cord, or the power cord might detach from the power module. The term power module refers to both the power module and the power cord. Step two: Verify that the electrical connections and outlet are functioning
  1. If the product uses a power module, make sure that the power module part number is the same as the part number listed in the User’s Guide to ensure that the correct power module is being used.
  2. Unplug the power cable or power module from the electrical wall outlet.
  3. Unplug the power cable or power module cable from any power strips or surge suppressors.
  4. If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it back into the power module.
  5. Unplug the power cable or power module from the back of the product.
  6. Wait at least 30 seconds, and then plug in the power cable or power module into the electrical wall outlet.
  7. Plug the power cable or power module back into the product.
  8. Turn the product on.
  9. If the product still does not turn on, plug the product into an electrical wall outlet in another room.
If the product turns on, a problem exists with the power in the original room. If the product still does not turn on, continue with the next step. Step three: Verify that the power cable or power module is functioning
  1. Verify that the power cable or power module is compatible with another product, and then plug the cable or module into the other product.
  2. If the power cable or power module does not work with another product, replace the power cable or power module.
  3. If another product is not available to test with, carefully inspect the power cable and power module for visible damage. If the power cable or power module is damaged, replace the power cable or power module.
If the product still does not turn on, continue with the next step. Step four: Verify that the product is not grounding out
  1. Unplug the computer USB or parallel cable from the back of the product. Figure 3: USB connection Figure 4: Parallel connectOn/Off switsch does not work - c00057176.jpg c00057176.jpg
  2. Turn the product on.
  3. If the product turns on, replace the USB or parallel cable.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Sergeant:
  • 378 Answers
No you will have to open the front cover to remove the control pannel.but its quite possible that you would have blown the circuit of the printer by unplugging it directly.many a times this happens.that needs reparing internally.
Reboot officejet 7410 all in one
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
You may perform the below steps
please take out the print cartridge
wait for the insert cartridge message to appear
unplug the power cord
Now clean the golden contacts of the cartridge with a cotton swab dipped in little alcohol.
wait for 2-3 minutes
plug the power cord back in
turn the unit on and reinsert the cartridiges
check for functionality
let me know in case you have any queries.
Nov 15, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 Unit is powered and the HP Invent logo is displayed on the screen with the progress bar moving at the bottom, but the power button is not lit and none of the other printer functions...
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Sep 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer won't POST
Unplug the power cord from the back of the printer and while its unpluged, press and hold # 6 on the printer together for 30 secs and after 30 secs plug the power cable back into the printer while holding it and then after pluging it release the buttons after 6 secs
Nov 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My hp officejet 7410 all in one display only hp invent and not respond
Perform a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Sep 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hp officejet 7410 all-in-one scanner don't work half the time.
Perform a hard reset on printer and also uninstall completely all software and then reinstall. Try scanner again.
If you have "upgraded" to another OS there is a possibility that the driver being used is not good for the new environment. If applicable, check that out.
If printer is out of warranty HP will do nada but refer you to a forum or suggest you get a new printer - an HP naturally!!!!!!!
Aug 27, 2017 | HP OfficeJet 7410 All-In-One InkJet...
7410 officejet
Sounds like the printer isn't passing the self diagnostics. Check for paper jams, pull the paper out and put it back in, check the ink cartridges.. unplug the equipment for about 30 minutes.
Mar 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanning from HP OfficeJet 7410 All-In-One to a Mac
Had same problem. Make sure you've closed any other apps. Itunes caused mine to fall over.
Jan 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
