Question about Mitsubishi VS-55705 55" Rear Projection Television
How to fix the video power supply for mit VS-4544 ?
How do I fix the video power supply on my mitsubishi VS-4544 rear projection TV? I have sound, but no picture. Will leave tv off for a day or two and picture back for awhile. Problem keeps happening more often now. How do I fix it without having to call a repairman?
  • 934 Answers
Let me preface what I'm about to suggest with my own comments. I've been a TV Technician for more than 20 years. That said, you don't fix it without calling repairman or you wouldn't have posted here. In this unit there are common lytic caps that should be replaced without question. By location number and value they are: C979 2.2uf/200v C531 2.2uf/160v C551 2.2uf/160v C981 22uf/50v C402 47uf/35v Next it might be a good idea to ESR test other caps in the B+ line. ESR stands for (equivalent series resistance) It's a way of measuring the cap's effectiveness in a circuit. There are testers on the market for just under $200.00 for the backyard technician and they are a must. Check the set for ring cracked solder joints. The symptom of leaving it off for awhile and then being able to get a picture suggests that it could be ring cracked in one or more areas, usually areas of high heat. When all else fails there is calling the repairman. If you don't know how to find a reputable shop in your area I might suggest contacting NESDA (National Electronic Service Dealers Assn.) who can give you some reputable shop contacts in your area. Good Luck! Bill
Posted on Jun 04, 2007
How do I hook up a dvd player to vs 4544?
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
May 29, 2012 | Mitsubishi VS-4544 45" TV
MITS VS-60609 HAS NO POWER AT ALL (DEAD)
Possible convergence IC loading power supply. Common. Big IC(s) with #s starting STK392(3).
Apr 17, 2010 | Mitsubishi VS-60609 60" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mits rear projection VS-4543
i wouldahve the power supply checked out,,,it sounds like it may be getting weak
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Turning on TV
check if there is any loss connection in the power supply circuit...
May 09, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Have sound but no picture
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Jul 07, 2007 | Mitsubishi VS-4544 45" TV
Older rear projection tv
I have the identical model, purchased in early 2000. I had the same issue, and called Mitsubishi service. Turns out there is a known problem with the video power supply. Mine was under warranty when it was repaired (in 2002), but by now yours probably is not. I recall the repair guy did the fix with no parts, just a soldering iron. If you're handy, you can probably get the details from MITS service and try the repair yourself. If not, I suggest the repairman route.
May 31, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
