Question about Galaxy Radios DX-99V 40-Channels Base CB Radio
Galaxy dx 99v
I have a problem with the req counter sometimes only first 3 lights up with nothing but 8's sometimes all of them just 8's hmmmmmm not sure why i bought it like that
  • 55 Answers
SOUNDS LIKE TO ME.. IT IS THE IC CHIP THAT DRIVES THE LED DISPLAY.YOU MY HAVE A COLD SOLDER JOINT AT THE CHIP........I WOULD OPEN IT UP TRACE THE RIBBON CABLE FROM....( MIGHT EVEN BE A BAD CONNECTION ON THE RIBBON CABLE..MOVE THE RIBBON CABLE AROUND FOR A BAD CONNECTION)TRACE IT TO THE CHIP WITH POWER ON BE CAREFUL OF AC VOLTAGE IN THE UNIT PROBE THE PINS OF THE CHIP WITH A PIECE OF WOOD OR PLASTIC WHILE LOOKING AT THE DISPLAY IT'S ONE OR THE OTHER GET A SOLDERING IRON AND FIX THE CONN......IT COULD EVEN BE THE LAST OR FIRST WIRE ON THE CABLE WHICH WOULD BE THE GROUND.....GOOD LUCK
Posted on Feb 21, 2009
I have a Galaxy DX 99v and when i key up the frequency counter scrolls up and down on it's one.what can i do to fix it?
the voltage regulator in the freq.counter board is bed and probably a diode common problem that need to go to a professional not a DIY easy job
Sep 17, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
Shorts & will not receive or send
Need more info ...but these 99v is notorious for cracking traces on the board. The frequency counter roams all over when this happens . It wont let it key up or receive. It needs a good tech to find it.
Jun 25, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a galaxy 99v when i key the mike the frequency counter jumps around.need help where to locate the problum
sounds like either a bad.mixer crystal or the vco is out.of wacky. if it is the crystal then you can try reseting it. it is a 10.240 crystal. heat the crystal wig a soldering iron for white 8 to 10 seconds. if that doesMr work replace it.
Aug 07, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
I want to know where I can buy a Galaxy Dx-99V in Canada.
Might be a problem finding a DX99V anywhere. That model has been discontinued. Best bet would be to Google it..
....Don at NTCB, Inc.
Jun 15, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Frequency counter displays two digets high from hump on fine clarifier adjestment on usb.27.186 insted of 27.185. also in am mode shows dead on with clarifer hump until mic is keyed thin dropes from 27.185...
Turn that fine clarifier a 1/4 turn or so to the right. I own a Galaxy DX99V and sometimes if that clarifier is just right it will drop down a hundredth of a MHz just like that when the mic is keyed. Your radio is just fine. Just adjust that clarifier a tad. The Galaxy DX99V is one of the best radios out there. I love them. -73-
Mar 10, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy 99 v freq counter is stuck on 29.840 on all channel it will not key up or recieve
Cold solder joint on Cristal leg or corrosion from the glue has eaten the leg off .
Jan 16, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
How hard is it to replace the volume knob on a galaxy 99? do they snap in or do they req. soldering... and will one out of a cobra 29 ltd work?
They are soldered by wires. no snaps. and will not interchange with cobra they have different ohm values. they can be order though. they are only a few dollars..
Dec 19, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
Freq counter just keeps going higher does not stop cannot talk on it
sounds like the mixer crystal. When this part goes bad it makes the radio go way off frequency. It will probably need replacing.
Nov 24, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
103 people viewed this question
Top Galaxy Radios Radio Communications Experts
Mike Charette
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
