Question about Dell 922 All-In-One InkJet Printer
Dell 922 All-in one ink jet printer paper feed
When I try to print, it will not grab the paper. Instead it says there is no paper in the tray. Sometimes, if I take a single sheet and feed it manually as it is trying to print, it will grab it and print. I have looked inside and don't see anything blocking it and it seems to print just fine, it just won't actually grab the paper unless I push it down in there manually.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 23, 2009
Printer not catching paper
You may have to clean the pick up rollers with alcohol or put a new roller in your printer.
If you have a printer with a tray, make sure it is set correctly for the paper you have installed.
It will try to grab the paper a number of times and will usually give you a paper jam error after a number of tries.
Jul 13, 2010 | Dell 922 All-In-One InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer won't take the paper - it makes noise but it is not grabbing the paper
The paper feed roller is commonly either dirty or has a sliver of paper inside. To clean it you should use denatured Alcohol with a lint free cloth. You have to remove all paper and the paper tray and may need to flip the machine to get access.
Nov 29, 2009 | Dell 922 All-In-One InkJet Printer
I have a Dell all in one 922 printer When I try
If your device is out of warranty, I'd suggest to clean the rollers again completely. What I mean is to remove the scanner lid and back cover, then clean all of the rubber rollers gently with alcohol and swabs.
Jun 14, 2009 | Dell 922 All-In-One InkJet Printer
Printer does not "grab" paper but can see parts turning
you have bad rollers. you can try to clean the roller with an alchohol wipe but I doubt it will help much. You need to have the roller replaced or get a new printer
May 27, 2009 | Dell 922 All-In-One InkJet Printer
Paper feed problem with Dell 922
Take a cotton swab and some alcohol and clean the rollers. They may be filled with paper fibers.
May 03, 2009 | Dell 922 All-In-One InkJet Printer
Print head problem
Do a reset:
Dell Printer reset
1. With the power on,unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket.
Dell Printers
To run a nozzle clean, perform the following steps:
1. Verify the All-In-One Printer 922 is powered on and connected to a computer.
2. Verify that the paper support (input tray) has clean, plain white paper loaded.
3. Press the Menu button.
4. Press the Down button until Mode: Maintenance appears on the LCD screen.
5. Press the Menu button.
The Dell 922 Maintenance Menu appears on the LCD screen.
6. Press the Down button until Clean Cartridges appears on the LCD screen.
7. Press the Start button.
The AIO 922 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 02, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
240 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
