Question about Roper RS22AQXKQ Side by Side Refrigerator
Freezer ice Ice from the freezer is dripping down through the vent hole into the veg. are. I cut the freezer off and cleaned the ice from the trey at the rear. Do you think this will solve the problem. the fan runs and the freezer get cold.
    Sniper:
  • 51 Answers
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 09, 2009
Westinghouse refrigerator leaking , dripping water and accumulates near bottom at fruit n veg basket. Some time it also forms ice layer on glass of basket. Any solution?
You have a clogged defrost drain tube, beneath the freezer evaporator (remove the back wall of the freezer compartment) there is a drip tray with a hole in it, the hole leads to the defrost drain tube- take a turkey baster and flush the drain with warm water until you hear it pour into the pan beneath the machine... Help Me Find My Model Number
Dec 11, 2016 | Westinghouse Refrigerators
Water is dripping on the top shelf of the refrigerator and I have cleaned and made sure the freezer and refrigerator are clean and the air flow is good but the water continues to drip about 1/2 a cup of...
sounds like the drain is blocked you have a plugged up drain in the freezer.when the machine goes into defrost the ice melts off the coil and goes down the drain in the freezer and drips down to the bottom pan where it evaporates,but your drain is blocked so the water can't drain correctly.you have to empty the freezer,remove the ice maker and shelves,remove the back wall and with a hair dryer melt out all the ice.after the ice is gone you have to clear the drain.i use a steemer to clear out the drain,if you don't have a steemer you can use like a turkey baster or anything that will blow through the drain line and clear it.when you think it's clear,pour hot water down through the drain to make sure it's clear.there's a heater you can install into the drain hole so this doesn't happen again,you can call your local parts store and tell them you need a drain heater or you can make one,get a 6 inch piece of house electrical wire,remove the ground wire from the casing,stick it in the hole until it hits the bottom of the drain,then leave enough to rap around the heater that melts the ice off the coil around a half inch and cut off the rest,when theheater comes on the wire heats up and stops the ice from blocking the drain. you want it long enough to go down the drain without hitting anything,4 to 5 inches is plenty,let me know how you make out
Jan 23, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is dripping from the top of refrig from what appears to be a control unit of some type.. The freezer and icemaker work.
If the water is dripping into the ref. from the freezser chances are you have a clogged drain where the water runs out of when the machine goes into defrost. Take everything out of the freezer and look at the back of the machine and see if you have ice built up. The vents that ru from the freezer to the ref. are loacted in the middle and chances are ice has gotten into them and is thawing and running into the fridge. Unplug the machine, take the back freezer wall off and clear the ice away. I use a screwdriver to tap into the drain hole to clear the ice but you can use hot water as well. Once you see water draining properly down the hole, put it back together and your good to go.
Nov 02, 2010 | KitchenAid KTRP22EM Top Freezer...
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Ice in bottom of frigidaire side by side freezer
clean out the drain hole with clorine bleach/blow out any gunk manually defrost unit.no hot water. no fault of siting.just a blocked vent...
Feb 08, 2010 | Frigidaire FRS26R4A Side by Side...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
We have a refrigerator model ET18NKXFW03 that drips water from the ceiling of the frig. We put a pan to collect the water but several times a week a stream of water leaks as well. It seems to happen more...
You will need to remove the food from the freezer and remove the ice maker if so equipped . Remove the 2 screws from the bottom freezer panel ( you will probably see a layer of ice here ) , and the 2 screws holding the inside rear freezer panel . Using a hair dryer , start in the center , below the coils , defrosting , until you see a drain hole . You want to defrost this hole ( hot water helps ) until water starts to flow down . Use a small hose inserted into the drain hole and blow thru it , to remove any unseen debris , built up inside the drain line . Reassemble the freezer .
Oct 11, 2009 | Whirlpool Refrigerators
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Fridge
ok pull the cover off the back wall of the freezer compartment where the evaporator fan is after look under the evaporator should see an aluminum pan with a hole there that's the drain hole for the defrost system if its frozen and that hole is stopped up then every time it defrosts the water will run in the freezer and freeze and also drip into the fridge remove the ice and clear the hole also check the drain tube in the back to make sure its clean
Jan 18, 2008 | Refrigerators
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Roper RS22AQXKQ Side by Side Refrigerator Logo
88 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
