How to solve a F1 problem in an IBM motherboard
  • Sean Osborne
    Sean Osborne May 11, 2010
    Please explain exactly what the problem is. Do you get a message saying "press F1 to continue"?
    What is the motherboard model?
    Genius:
  • 1,605 Answers
F1 for IBM is telling you there is no operating system.
press F1 to install.
change the internal battery, you may need to rest the BIOS, generally it will find all the devices.
Posted on Jan 08, 2009
Ibm 2akt49aus
Just guessing, but I'd system your CMOS battery needs to be replaced. Open the computer side panel and search the motherboard for a small, round silver batter about the size of a nickel. Use your fingernails to push the silver click to one side and take out the battery. Buy a new one from Wal-Mart and put it in with the smooth side up then re-enter the CMOS setup information and the problem should be solved.
May 22, 2014 | IBM Lenovo ThinkCentre® M51 (814339U) PC...
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
MY MOTHER IS IBM 09k9982 011 ATX SO HOW TO 1ST DIVISE CD ROM
login to bios setup then set your first boot to cd room
Jul 13, 2010 | IBM (09N5424) Motherboard
What is logon chriteria
hit F2 or DEL or F12 at single time wait for screen show press --X--- key to enter bios
Jun 20, 2010 | IBM (09N5424) Motherboard
Startup problem
check the device like ram,or hdd. or change the battery cmos.. then try again
Jun 14, 2009 | IBM (33P0825) Motherboard
IBM D845 MOTHER BORD AUTOMATIC BOOT PROBLEM
you have lost your system files, if there is chance can you remove the RAM and fit again and then start if it doest not work then plz mail me
thanks
zaki
zakipervez@gmail.com
May 28, 2009 | Lenovo ThinkPad R51
Access IBM buttom does not function
this will occur if you have installed a clean copy of windows i.e not the one supplied by IBM and/or you have uninstalled the access IBM software (or it isn't installed in the first place) . You can get the access ibm software at the manufacturers website. The ACCESS IBM button will not function during boot up if you have removed the access ibm rescue and recovery partition. It can also be activated/deactivated from the BIOS. ( Press F11 or F1 0 during boot up )
Jan 08, 2009 | IBM ThinkPad R50e Notebook
CMOS erroe 0193
Remove the CMOS battery and also the jumper on the motherboard to reset the bios.
Oct 12, 2008 | IBM NetVista PC Desktop
49p1605 manual
Start up your computer, Hit F1 go to Bios and see which is the model number of your IBM motherboard (usually is a number like this: 8313-BU7 (example))
Then go to Lenovo.com >> Support Drivers
Select >> Desktops >> Netvista >> Model Number (put yours) >> OS
And get the drivers and all the info about your machine.
Please dont forget to rate my help! :-) Have a great day!
May 01, 2008 | IBM (49P1605) Motherboard
How to go to boot settings in IBM 6578-PBU machine
during bootup press del key if not press f10 if not try f1 or f2 or f7. i hope it helps
Apr 17, 2008 | IBM NetVista A40p PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
