Question about Samsung S860 Digital Camera
Camera screen crack
Where can i get a LCD screen for a s860 & how much for it?
  • 10,594 Answers
Check LCD of Samsung S860 LCD in Part Store.
Posted on Jan 08, 2009
Vertical stripes on digital camera lcd
The fact that it takes the pictures ok confirms that it's not the ccd which has failed.
If the menus on the lcd screen are also distorted then it confirms that the lcd screen itself is faulty and this is replaceable. If the menus display just fine, then it's the internal circuit board which has a problem and replacing that is not normally viable.
Either way, the Samsung s860 is a budget model available for as little as £60 new, so even the most minor repair will cost more than replacing the camera: unless it's still under warranty (one year from purchase date) it's definitely uneconomic to repair. Samsung themselves wouldn't normally bother; a warranty claim usually means they chuck your camera away and send you a replacement.
If you're in the UK click here for details of how to proceed with Samsung.
I hope that I've helped, if so please remember to rate my answer.
Feb 19, 2010 | Pentax Optio 60 Digital Camera
I have a cracked screen can i get a replacement ?
If you are talking replacement of camera then it is not possible but if you are saying regarding replacement of LCD screen then you can get the required part from samsung authorized service center.
Thanks for using fixya.
Oct 18, 2009 | Samsung S860 Digital Camera
Screen stays black
Move all the pictures to the camera memory card from your internal memory. Since you have to open the camera, the pictures will be lost otherwise. Save your pictures. If you do not have a memory card, transfer all the pictures to your computer.
Remove batteries from the camera.
Purchase a replacement LCD screen, specific to a Samsung S860 camera. These replacement screens can usually be purchased directly from Samsung or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras.
Use the mini screwdriver to remove the four screws from the back of the camera. Be careful with this step since the screws are tiny.
Take the back cover of the camera off carefully. Inside the camera, there is a piece of foam that supports the LCD screen. Do not remove the foam. Set the bottom portion of the camera to the side.
Turn the top portion of the camera so it is facing upward. Notice how there are clips holding the LCD screen in place. Carefully lift these clips up and remove the broken LCD screen. The screen clips are extremely fragile and break easily if they are lifted too quickly. A gentle touch is key.
Place the new screen down gently and replace the clips. Gently dust the screen so fingerprints are removed.
Turn the top portion of the camera down so the screen is pointing down. Place this on top of the foam padding.
Turn the screws carefully. The best way to screw the back of the camera in place is to first screw in one corner, move to the corner that is diagonally across and turn that screw. Repeat for the other two screws.
Replace the batteries. Turn the camera on and see if it is function
Sep 02, 2009 | Samsung S860 Digital Camera
Blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Samsung s860 camera got dropped turns on but screen is only white
dropping the camera might have caused damage to your LCD screen, best advise I could give is to send it in for repair
check if you can still view old pictures or if the on screen displays are visible, it will narrow down if the problem is with the lens or the screen
hope this helps
Mar 30, 2009 | Samsung S860 Digital Camera
Cracked screen where can i get it fixed Well my screen is cracked it has a thick black streak going through it, with the white all around it.
at normal and local camera repair center you can easily get it fixed.but if that repair center is not in your area or if you r not aware of it just click the link below for reparing estimates cost  of camera
http://www.advancecamera.com/repair
                     the link will help you to get the device repaired and serviced
·                                 Free estimates.
·                                 Reasonable rates.
·                                 Fast, friendly, and personal service.
·                                 Top quality repairs.
·                                 Advance Camera 1 Year Warranty
Mar 03, 2009 | Samsung S860 Digital Camera
How much can i get a lcd screen for a samsung s860 digital camera and where can i get it?
Contact the Samsung tech support. Most of these manufactures will not sell the parts to the end user. They may insist that you send in the camera for service to the service rep in your area.
Jerry G.
Jan 08, 2009 | Samsung S860 Digital Camera
Samsung S860 Digital Camera Logo
103 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
