Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting! I have a Panasonic Toughbook CF-18 that will sometimes boot to desktop but freezes. Cannot enter anyfiles at this point. Was damaged due to malware. trying to boot from usb but cant seem to make it work. any suggestions on what to do. I do not have an external anything. just usb, i have one of 3 recovery disks for toughbook, cd #1. Need help, any ideas welcome.
  • 56 Answers
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Posted on Apr 16, 2009
Is there a way to recover the Panasonic Tablet PC back to factory default settings, without the CD? I don't have the CD so can you please tell me how to recover the PC?
Yes : boot from the recovery partition (you'll need to give the boot process some more time to keep the choice of the bboting partition displayed :
Windows+Pause, Advanced, 3rd "Parameters" button, change to 10 seconds.)
Jul 03, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
How do i turn my laptop in safe mode
Press power button and press F8 repeatedly until you get the black screen offering option to boot the system into safe mode.
CreativeTECH
Dec 08, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I...
reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
May 07, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
My Panasonic Toughbook T2 was shut down properly and kept for about a month. now it does not boot. Even inital BIOS check function is not performed. Though HDD movement can be heard. Checked RAM by...
Is there any chance the video output is switched to feed the rear VGA connector? ie the screen is black due the video being routed away from the screen. Try hitting F5 key.
Can you hit the Delete key to try and enter the bIOS screen? (it may be another key such as F1 or F2. See your Toughbook manual)
Can you have someone make you a bootable USB thumb drive and try booting up with that?
Its also possible that the hard drive has failed, but usually the BIOS POST check will initiate and indicate a failed hard drive or bad RAM etc
Can you remove the 2.5 inch hard drive? Usually its accessible under a removable panel under the laptop.
Feel free to ask more questions.
Cheers,
Steve
PS have you tried the discussion forums on the Panasonic website?
May 03, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic toughbook cf 18
You will, at the very least, need to have the screen and screen cover replaced. If the hinges also damaged the bottom case to which they are attached, then it too will need replacing.
If you can't get it repaired locally, let me know.
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic CF-18
The command.com is a key file in the booting up process of computers. You either have a virus that destroyed it, or your hard disk drive is failing. Try going into the CMOS and make sure the CD is listed in the boot order and first, then boot to system CD.
Oct 17, 2017 | Panasonic Toughbook 18 Convertible Tablet...
Setup password
i think the computer is asking for bios pc if it is bios then you have to open the case and remove the bios battery for five sec.before this you have to remove the power plug.after five sec. just resit the battery and put the power plug back and switch it on.
plz post your findings
Apr 23, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
693 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
ddalecki
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
