Canon DR-5020 Error Code E21
I am getting Error Code E21 when I power on the scanner. Any suggestions? Thank you advance for your assistance.
  • 490 Answers
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
S. Mohan, Chennai, India
Posted on Oct 18, 2009
I have a canon dr 5020 that just started scanning slowly
Check if there is enough disk space in the comp target area. Run defrag and scandisk.
S. Mohan, india
Mar 01, 2013 | Canon DR-5020 Path-Through Scanner
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Can not install canon dr=5020 scanner/ installed scsi card then went to canon's site and downlaoded drivers for windows xp-computer asks to add hardward but does not find an "inf" file in the 6...
First ensure that the SCSI card is installed properly. Download DR 5020 drivers from http://software.canon-europe.com/products/0000672.asp and install them. Use CapturePerfect ver 2 or 3 to scan documents. With SCSI based scanners/devices, one should power-on SCSI device first before starting the Computer.
Feb 17, 2011 | Canon DR-5020 Path-Through Scanner
DR-5020 Path-Through Scanner: can't fing the drivers for the canon dr5020 scanne...
You can down load drivers from Canon Europe site. http://software.canon-europe.com/products/0000672.asp
S. Mohan
May 18, 2010 | Canon DR-5020 Path-Through Scanner
Canon dr5020 c02 error
When the top cover is open you get message C01, when the top portion of the top module is not in position, you get C02 error.
S. Mohan
Mar 26, 2010 | Canon DR-5020 Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
There is no power supply on my cannon scanner DR-5020. Do these scanners have a fuse and where is it located?
There is fuse, but in the Power supply board. Check if LEDs are blinking in the back PCB and on the right side. Do a basic check also, check if the power cable is good. many times we assume that is perfect, but not necessarily.
S. Mohan
Jul 10, 2009 | Canon DR-5020 Path-Through Scanner
Canon DR5020 E21 error
Canon Scanners are reliable. Canon has chosen error codes logically, 'P' os Paper related, 'C' os cover related, 'E' is Engineering Support related.
E21 is Document Motor Trouble. E2 is Separation Motor Trouble. Check of connection and load or you may to replace motor. Try connecting the motor to a different location and if the error is same, probably there is no motor fault, if it changes then it definitely motor fault. As a last thing you may need to change the PCB on the side.
Jul 03, 2009 | Canon DR-5020 Path-Through Scanner
Canon Dr-5020 grabbing multiple pages
Wipe the rollers with a damp cloth thoroughly. Remove all the dust in the glass for a claen scan. The red color roller roller in the bottom needs thorough cleaning, rotate with hand gently (in power-off mode) and clean it thorughly. No solvents pls, except Isopropyl alcohol for cleaning
S. MOhan, Chennai, India
Mar 03, 2009 | Canon DR-5020 Path-Through Scanner
Error Message-- Error in shading position (-4431)
The issue at hand here is a sensor error. Cut the power to the machine for at least five seconds. Then reboot the scanner and the sensors should reboot. This solved the problem for us. Good luck to you.
Nov 21, 2006 | Canon DR-2580C Path-Through Scanner
435 people viewed this question
jasbo
jasbo
