Question about Canon PIXMA iP4000 InkJet Photo Printer
Getting an error that the door is closed, but it isn't
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Keyboard from the USB port and reinstall the CD software program. When the program asks you to connect the Keyboard to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 24, 2009
Need gaskets for CSX20E Hotpoint side by side
Seals don't lose their magnetism. Check the door closes all the way round and adjust the hinges if it doesn't sit straight. Check there isn't a relief valve frozen up or blocked (it allows air to escape when the doors are closed). Check the drawers are fully pushed back in and not stopping the door closing properly
Sep 11, 2012 | Hotpoint Refrigerators
Freezer door ice dispenser flap will not close completely. The cold air is leaking out of the freezer. What can I do to fix?
There are multiple parts to the dispenser for GE. You say that door isn't closing properly, which could mean that the solenoid isn't working properly, or that the door flap retainer itself is broken, I want to say that they make a complete kit for it but not for certain,
Jun 02, 2012 | GE Refrigerators
Driver Side Door wont open from inside or outside. also passenger side door wont close! Help
On the passenger door,make sure the latch isn't in the closed position(have someone pull on the handle while pulling the latch mechanism with a screwdriver)The drivers side is gonna be interesting.You might be able to get at the door latch mechanism by rolling the window all the way down,and use a coathanger or similar tool to operate the linkage levers that way.
Jan 01, 2012 | 1988 Chevrolet Corsica
Trying to clean my whirlpool oven. when it start button, an E1 - F5 comes up. What is this telling me.
What the F5-E1 error code means is that the door lock asm. is not operating so when its suppused to close and lock the door to self clean it cant do it since something is wrong with the latch/lock assambly
Some of the things that would need to be checked to see why the latch isn't working are;
the latch position switch,the latch itself to be good and opening/closing, & the part called the soloniod that is what operates the latch so it could open or close
GENE
Sep 18, 2011 | Whirlpool Ovens
The interior lights wont turn off. they melted the old light bracket so i replaced it and the lights still wont go out
It sounds like you have a switch that isn't closing when the door shuts. I'm not overly familiar with the LG's, but looking at the Sears Parts Direct site, it looks like the door switches are in the hinge covers on top of the unit. There should be two of them, one for each door. But, only one has to not be working to keep the light on. The first thing I would check is to make sure the hinge cover isn't loose or out of position. The switch should close when the door closes. If the hinge cover moves, then the switch won't close. If everything is tight and aligned, then one of the switches is bad. That can be checked with a volt meter that does continuity checks. Unplug the unit before checking because those wires should be hot at all times. If you don't have a meter and want to do trial and error, just buy one switch since they both are the same. Here is the parts diagram showing the switch locations and part numbers:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LFX25960ST/3204/0161000/K0810255/00001
The switch is 402A on the diagram, located on top of the box. If you click on the parts diagram, you can enlarge it to get a closer look.
The switch part number is 6600JB3007E
Hope this helps
Aug 11, 2011 | LG LFX25960ST Stainless Steel French Door...
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
Jul 20, 2011 | Bosch WFVC6450UC Front Load Stacked Washer...
Hi I have a WFS1071bd Whirlpool washing machine. I have had problems when you press start it sounds like water is going into the machine then it starts flashing 'door open' error. I have checked...
Sorry but 'door open' error message means that it thinks the door IS open even when it isn't! There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 07, 2011 | Washing Machines
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
My printer says the door is open when it is closed!
the iR1600/2000 will show the message close printer door if the copier paper path door ( on left side of copier, beneath the bypass tray are paper path door in level with paper cass. ) isn't closed well. Open the door and close them with some "gentle" force. It is good idea first to push the paper path guide, before closing the door.
Hope that helps!
Apr 21, 2011 | Canon ImageRunner 1600 Copier
Can not close the door
how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
Canon PIXMA iP4000 InkJet Photo Printer Logo
35 people viewed this question
old marine
old marine
