Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Black Vertical Bar
My Akai 42 inch Plasma TV has a 1/2 inch vertical black bar that splits the picture in the middle of the screen. When I turn the TV on, sometimes it is there, sometimes not.It will come on and be intermintent or sometimes it will stay on all the time. Can anyone solve my problem? Can I continue to watch the TV or will the black bar burn into my screen?
  • 3 more comments
  • swil Wilson Jun 08, 2007
    Black Vertical Bar
    I made a mistake about the size of the black vertical bar. It is 1 1/2 inches wide, instead of 1/2 inches wide. Will TVTEK's solution below still be the same?
    Thank You,Swil
    Solution from TVTEK
    It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
  • swil Wilson Jun 09, 2007
    TvTek, We really appreciate the solution you gave us!! We will have it fixed, Thanks to you!!
    Swil
  • lostintvland Nov 25, 2007
    I have the exact same problem, model PDP4247, manuf 11/03. Thanks for the solution tip. Now to find someone that knows where to look and what to solder...do I dare try it myself?
  • Charlesas Dec 22, 2007
    I have the same problem but the bar is not always black. It would be great to see a diagram of the point where solder is needed. I haven't had the nerve to attempt a fix as yet!
    cs
  • Anonymous Feb 17, 2008
    We've ccecked the resistors and they are ok.What else might be the problem?
    President:
  • 1,284 Answers
Posted on Jun 08, 2007
  • Don
    Don Jun 08, 2007
    Yes, in fact that is more of a reason to point to those address boards.
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
While watching our 42 inch Philips Plasma tv the other day, a vertical black bar showed on the screen. Based upon the fact that it appears no matter the input (HDMI, composite etc. We turned off the tv...
If you get the black bar and it is vertical, not horizontal and it is on every input, your panel has failed. It is more economical to buy new than replace the panel. Try a Sony. Mine rocks.
(If the bar is horizontal, it may be an empty closed caption box)
Aug 09, 2010 | Televison & Video
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
579 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
