Question about Epson CX4200 All-In-One PSC Printer
My CX4200 is printing very close to the left edge of the paper.
This started after I cleared a paper jam the other night. It started making unusual noises after the paper jam was cleared but it seems to print ok except the left margin is about 1/8 inch to the left of where it normally is for emails and it makes these funny noises and now takes longer to start printing.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
Important:
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Print Unable 34
There might be some paper left in the machine. Check the very edges espacially the left side (seeing from the front).
Another reason could be that the encoder strip isn t in right position or is stained from ink.
Anyway try the first solution first.
If you stll have trouble try to open the printer:
http://www.fixya.com/support/t211210-brother_mfc845cw
and have a close look to the encoder strip + disc (and look out for some paper in the edges... ;-))
Mar 22, 2008 | Brother Multi-Function Center MFC-240C...
Paper jam
If the jammed sheet is entirely within the printer, remove the sheet as follows:
r_1.gif Make sure that the printer is turned off.
r_2.gif Open the printer cover by pressing the latch on the left side of the printer and lifting the cover up all the way.
r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Opening the printer cover exposes the fuser, which is marked CAUTION Hot Surface Avoid Contact. Be careful not to touch the fuser. If the printer has been in use, the fuser may be very hot.
hppe004.gif 1. CAUTION Hot Surface Avoid Contact
r_3.gif Remove the developer cartridge.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif When removing the developer cartridge, never touch the developing roller under the flap; otherwise, print quality may decline.
r_4.gif Remove the photoconductor unit.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Never touch the photoconductor unit's light-sensitive drum; otherwise, print quality may decline.
r_5.gif Remove the paper from the paper path.
r_space.gif r_note.gif Note: r_space.gif r_space.gif If paper is jammed at the fuser, grasp the bottom of the paper and pull it out.
r_6.gif Reinstall the photoconductor unit, and then the developer cartridge.
r_7.gif Close the printer cover.
r_8.gif Tap the edges of the stack of paper on a flat surface and carefully reload it into the MP tray. (Do not reload curled or wrinkled sheets.)
Printing automatically restarts from the page that jammed. If the Paper light stays on after removing all jammed paper, open and close the printer cover to clear the error.
Oct 16, 2007 | Lexmark X7170 All-In-One InkJet Printer
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
