Question about Kenmore Room Air Conditioner
Air conditioner pop and then blew refriderant or something
Air conditioner tripped our curcuit breaker. Reset circuit breaker and plugged airconditioner in to turn on the fan only, heard a pop and then it blew refriderant or something (smelled a little like ozone)
  • robert788 Jan 08, 2009
    If it is a compressor problem, is it repairable or just go get a new air conditioner?
  • Kenmore Master
  • 8,220 Answers
Inspect the capacitor for failure. if it is not swollen or leaky then the compressor might be gone.Air conditioner pop and then blew refriderant or s - 264f733.jpg
Posted on Jan 08, 2009
  • Dan Webster
    Dan Webster Jan 09, 2009
    With the price of ACs like they are today verses the cost of labor and parts I would say get a new unit.
Curcuit Breaker appears to be on but no power?
It sounds like something in that circuit is causing the overload. Disconnect anything that is in that circuit, flip the breaker, and one item at a time plug whatever was on that circuit back in until it trips again. Then try that item in a different circuit and see if it does the same thing. It could also be that the breaker is worn out and is tripping at a lower point that it supposed to. In that case you would have to replace the breaker.
Mar 04, 2015 | Electrical Supplies
My fujuitsu works on all setting but when on heat it trips the curcuit breaker
The coil for the three way valve is to earth. Disconnect it and try heating mode again. if circuit breaker doesn't trip proves the coil is at fault.
Apr 27, 2014 | Heating & Cooling
Why does the reset button on my air conditioner keep popping out when i plug it in
You are tripping that outlet's breaker. Either too much is on that breaker and circuit or that circuit is not big enough, enough current to power that unit.
Aug 13, 2012 | Crosley Heating & Cooling
My Maytag Portable Air Conditioner Model #M6P09S2B keeps popping my breaker. Can you help me solve this problem?
This can because by a couple of things. An electrical fault within the AV Unit or the electrical circuit the unit is plugged into has other electric appliances on the same circuit. Thereby, overloading that one circuit. Try plugging the unit into another outlet that is on a different circuit. If it trips a circuit breaker then, the problem is within the unit. In which case, you will need to have the unit checked and serviced.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Maytag M6P09S2B Portable Air Conditioner
LG M8003L Air Conditioner does not power on
i think there may be damage to a small electrical component in the circuit board which probably fried just before breaker popped open
Aug 12, 2009 | LG M8003L Air Conditioner
Exact same thing happened to me
the 20 amp circuit should more than handle a 6.5 amp load, the 6.5 is the rating of the operating AC not of the circuit that is required to be attached to it. If the "pop" noise is the breaker tripping the circuit may be miswired, the unit mayhave a short to ground, as the circuit breaker is designed to trip on an over amp situation or a situation where 20 amps is exceeded. Di you verify that the circuit voltage id correct, eg: 220 volt or 110 volts. and that it matches the unit nameplate.
Jul 20, 2009 | Goldstar KG6000R Window Air Conditioner
Circuit breaker on power cord does not reset
why did it trip? If you push test and it does not trip, check your circuit breaker in your panel
Jun 20, 2009 | Friedrich QuietMaster RS10J10 Air...
Furnace keeps tripping circuit break
Furnace. To confirm use an Ampprobe or other brand ampmeter and see how much current is being drawn. If it is more that 80% of the breaker rating, it si for sure the Furnace.
Jan 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
The power plug keeps tripping. when i press the button on the plug. it just trips.
Either there is something wrong with the unit or you have something else plugged into the same circuit. Air Conditioning units draw a lot of power and will trip a breaker if there is a moderate load on the same circuit. Try plugging it in to an outlet that you know doesn't have anything else on it. The other thing you can do is see what else turns off when the breaker trips, that will tell you what else is on the circuit.
Sep 15, 2008 | Haier Heating & Cooling
AIR CONDTIONER TRIPS CURCUITS
Possible loose connections on the wires to the breakers,
or in the unit. loose connections casuse the wire to overamp and trip the breaker.
Also it's possible the breaker it's self is bad.
there ar also other possibilites but the 2 formentioned is the most common cause.
May 15, 2008 | Heating & Cooling
Heating & Cooling Logo
277 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
