Question about Amana ARSE66MB Side by Side Refrigerator
Freezer is cold but refrigerator is not.
My Amana side by side started warming up in the refrigerator compartment but was staying cold in freezer. It has three blower vents in the refrigerator (one in back and two in front that blow into the door compartments). I could not feel any air coming from any of these. I cleaned the coils underneath, unpluged it and let it defrost. after about five hours, I plugged it back in and it seemed to work great. I could feel the cold air blowing into the refrigerator compartment. It worked well for almost 24 hours. I then noticed the problem came back. I am pretty handy but have never worked on an appliance before. I think it may have a problem defrosting automatically but, I don't know what part would need to be replaced or where to find it. Please Help.
  • Richard Houser Jun 06, 2007
    Thank you, I'm sure it is the defrost system but, how do I check each part so I know what to replace? I have a tester and I'll be able to check the resistance of the heater coil (what should it read?) but how do I check the t-stat and the circuit board? Where do you reccomend I purchase the part from? Thank you again for your advice.
  • 237 Answers
If the fan is still working (and it sounds like it is, then the evap coils are frozen up. A typical failure is the defrost bi-metal t-stat but I've also seen LOTS of the adaptive defrost circuit boards fail on this model. I would lean toward the circuit board first as the culprit. See part 711 http://www.partselect.com/Schematics/Maytag/32266.gif http://www.partselect.com/xq/aspx/Inventory.51814/qx/PartDetail.htm?SourceCode=5&ModelNum=ARSE66MB
Posted on Jun 03, 2007
Mod# ABB1922FEW... the freezer works fine but the refrigerator is warm, there is very little food in the freezer.
If the vent from the freezer to the refrigerator is not blocked with food or paper particles, then it's likely the defrost system is not working properly. You will need a technician to determine the cause.
Jan 22, 2013 | Amana AFB2534DE Bottom Freezer French Door...
Two year old Fridge with bottom freezer and french door upper. Cold freezer and a warm fridge how can we correct this?
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
Jun 27, 2011 | Amana Refrigerators
Fridge doesnt stay cold
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Freezer create ice and refrigereitor is warm amana atATB1836ARB
It's probably the fan in the freezer compartment.  It is supposed to blow cold air from the freezer through the ducts into the refrigerator.  It's either iced up or dead.
Aug 26, 2009 | Amana Refrigerators
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Mar 06, 2009 | Amana AFD2535DES French Door Refrigerator
Freezer side not freezing
It is possibly your defrost element which is not working causing a build up of ice and reduced airflow through the freezer compartment. This is located behind a cover in the freezer compartment. It is best to change both the element as well as the defrost limiting thermodisc which is attached to the fins of the evaporator.
Mar 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana fridge
is the freezer cold. the freezer is acualy the only refrigeratted compartment . it has the evap coil in the rear wall and a fan to cerculate the air . a potion of the air is let into the food compartment . most comonly the freezer defrost system can be the fault. so i would requier answers to the first question. is the freezer compartment working. hope this helped
Oct 19, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side
call a technician, you need a freon recharge.
Jul 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana ARSE66MB Side by Side Refrigerator Logo
188 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
