Question about Nextar MA933A MP3 Player
I can't connect the mp3 player to my computer
No entry mp3
  • aekllmmo Jan 12, 2009
    Only clik whit the right button and refresh when a web pag
I HAVE DIGITAL MUSIC PLAYER OWNERS MANUAL MODLE NUMBER IS 50381 AND I DONOT KNOW HOW TO PUT SONGS INTIO MY MUSIC PLAYER CAN HELP ME THANKS
Posted on Jan 08, 2009
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
STEP 2 - Check under Device Manager
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
STEP 3 - Refresh the drivers
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Not connet on computer
Hi, Sony NWZB133F MP3 Player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sony NWZB133F MP3 Player not recognized by a MAC OS
STEP 1 - Connect the Sony NWZB133F MP3 Player to the PC
NOTE: Sony NWZB133F MP3 Player can connect to your computer in MSC or MTP mode. Exceptions are Sony NWZB133F MP3 Player Connect and Sony NWZB133F MP3 Player Express which only use MTP mode. MTP mode is the recommended and default method for Sony NWZB133F MP3 Player when used with Windows OS.
The Sony NWZB133F MP3 Player will show up on Device Manager's right pane as:
Have a nice day....
Feb 22, 2011 | Sony NWZB133F MP3 Player
I have my mp3 player plugged into the computer and when I go on Itunes it does not show up.
Is this on a Windows computer?
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your MP3 player.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Computers & Internet
How do i access mp3 files on the SD card
Put the card into the player, connect your player to your computer via USB, and open up "My Computer".
You will either see the player under the computer as something like "Sansa Clip", or you will see two new drive letters, one for the Clip's internal memory, and one for the microSD card.
If you see the two new drive letters, double-click on the one associated with the microSD card, and you will see the files on it (probably in folders, like "Music").
If you just see something like "Sansa Clip", double-click on that, and you should see two entries, "Internal Memory" and "Expansion Card". Double-click on "Expansion Card", and you will see the files on the microSD card.
Feb 05, 2010 | SanDisk Sansa Clip MP3 Player
When i plug my Nextar MA797 20 mp3 player into my computer my computer keeps saying that the usb device has malfunctioned or windows does not recognize it but it worked fine before.How can i fix this or...
Check and refresh the drivers in Windows, for a Portable Device.
1 - Connect your player to the PC
-> 1. Right-click My Computer, and select Manage.
NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode.)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh or reinstall the drivers.
2. On the top menu, click Action then select Scan for hardware changes. The computer should pick the player and try to reinstall the drivers. *** See again step 1 and 2. See this guys tip for an explanation of MTP and MSC Solve your MP3 Player Connection Problem.
Jan 12, 2010 | Audio Players & Recorders
Got 6730 Alba MP3 Player. Copied a number of File Folders from old MP3 player but when I go into Music/Albums menu. it is only showing me 4 entries
Connect your mp3 player to your pc and then format it and then again fill some songs in it then it will work.!
Thankyou. :)
Jan 08, 2010 | Audio Players & Recorders
My ipod is flashing no entry sign and do not disconnect,i cant transfer any music of my laptop
Is it still connected to your computer? Cuz if it is, it will show up that thingy.
Jan 06, 2010 | Apple iPod MA446LL/A MP3 Player
Window media player is not recognizing my sansa m230
Refresh drivers - connect player to PC. Right-click My Computer & select Manage. Click Device Manager on left pane. Player will show on right pane as USB Mass Storage device or Portable Device.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers: right-click the entry with the error & select Uninstall. On top menu, click Action then select Scan For Hardware Changes.
Feb 21, 2009 | SanDisk Sansa m230 MP3 Player
My mp3 doesn't play music
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | JNC Computers SSF-35 (512 MB) MP3 Player
Nextar MA933A MP3 Player Logo
41 people viewed this question
Top Nextar Audio Players & Recorders Experts
lolthepcman
ray gallant
Paul Chapman
Paul Chapman
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
