Foam under ink cartridges has come loose.....!!!!
When I tried to clean the nozzels I got smeared ink on everything I tired to print then noticed the far left little piece of foam had come loose and lodged in that side of the opening.
  • 30 Answers
It sounds like you need to replace the cartridges. Most newer companies make their cartridges where they are not user servicable.
Posted on Feb 05, 2010
All of a sudden my hp 932c printer started printing funny in color. I was printing pictures and the prints came out like a heat resolution type picture. I then got new ink cartridges, it did not fix the...
quite often inkjet heads will dry up and clog. try a clean heads sequence in the printer properties panel. do this until it prints the clean nozzle page properly. If the ink cartridges have the print head attached to them (some dont) you can dab them on a paper towel with windex or vinegar until they show a nice clean line when dabbed. if you cant get the print heads out , then you just need to continue running the clean nozzel application until it prints the test nozzel job properly. This is the reason I will not buy any more inkjet printers. only Toner based machines. cheers.
Aug 25, 2010 | HP DeskJet 932c InkJet Printer
Black smear on underside of paper
Sounds as though you have a leaking black cartridge and ink has got on to the platen.
Open the machine as if you replace a cartridge. Remove the whole print head unit. You can do it without taking the inks out. What does the underneath of the print unit look like? Pretty messy I'm guessing.
Clean all the surplus ink of the base of the print head and put it to one side. Now look at the platen (that's the long strip of metal that will be underneath the paper while the print head is passing). Clean that with a damp tissue. If you look carefully at that metal strip you should find a long wiggly piece of foam inset into a cut-out in the metal. Gently prise it out and wash it in warm water - take are not to stretch it or break it.
Now with a torch or lamp look at the right hand end where the print head goes when it is resting. That may well be messy too. Using dry paper towel try to absorb as much ink out of that area as you can (you'll get you fingers very dirty!).
When you think you have got as much out as you can use a damp tissue to clean off any dried on bits.
Now carefully refit the foam bit back into its slot - it will only go in one way - and then refit the print unit.
Close the lid and do a print. Hopefull y everything should be OK.
May 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How do I clean the printer nozzles as it leaves streekes on printed pictures?
If the ink is smearing, it probably is not getting enough drying time. The ink drying time is a period of time inserted between pages to reduce the chance that a page will smear the one below it in the output tray. This time is factored into the time between when the first page finishes and when the next page finishes. Printing will pause temporarily if more time is needed. The time it takes for ink to dry varies greatly depending on paper type, printer driver settings, humidity, and temperature. In addition, the paper and print settings may affect the speed at which the ink can dry:
  • Transparencies require much longer drying times than other paper types.
  • Some store-branded photo papers do not allow ink to dry correctly because of the coatings used in their manufacture.
  • Printing in Best mode can increase the dry time.
Resolving the problem If the ink smears, increase the drying time. To increase the drying time in Windows, follow the steps below:
  1. When ready to print, click File , click Print .
  2. Depending on your driver version, click Properties , Settings , or Preferences and follow the steps below depending on the option.
    • For Properties or Settings , follow the steps below:
      1. Click the Advanced tab.
      2. In the Extra Dry Time section, move the slider toward More .
    • For Preferences , follow the steps below:
      1. Click the Basics tab.
      2. From the Basics tab, click Advanced Features .
      3. In the Extra Dry Time section, move the slider toward More .
  3. Try a sample print and see if the drying time needs to be increased more.
To increase the drying time for a Macintosh computer, follow the steps below:
  1. From the File/Print Menu , select Ink under the General tab.
  2. In the Dry Time section, move the slider toward More .
Other steps that will reduce ink smearing If the ink still smears when printing, try some of the following suggestions:
  • Decrease the amount of time it takes for the ink to dry by decreasing the print quality to Normal or Fast mode.
  • Try printing on a different type of paper or on paper from another manufacturer. Paper formulas are different between manufacturers and may have a coating that causes the ink to be absorbed at different rates.
  • When printing large graphics or photos on plain paper in Best or Normal modes, improve the results by using heavier paper. Paper that is rated at 90 g/m2 (24 lb.) or higher will not curl or smear as easily as paper of a lighter weight.
Mar 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Canon Pixma MX 310 print smears.
You need to clean the bottom of the printhead, and use a Q-tip to clean the wipers on the clean station that is on the right side where the printhead parks. There are 2 or 3 squeegees there that wipe the bottom of the printhead and when there's too much ink it stays on the printhead causing the smears.
Jul 23, 2009 | Office Equipment & Supplies
Not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
May 02, 2009 | Epson Stylus C84 InkJet Printer
Button flashes, won't print
Actually, I figured this out all by myself. After I'd tried everything else, I took out the black printer cartridge and noticed there was black ink smeared all over the back, so I took some cleaning solution that came with some ink refill kits I had, cleaned off the contacts on the cartridge and on the back of the printer itself where the cartridge meets the printer, and it suddenly started printing again. TaDa! It's going again!
Apr 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Leaking Black Colour
Understand when I suggest replacing the printer, it isn't that you can't fix it or that I'm not answering your question. But to do so will require cleaning every inch of the internal components. The ink will stain everything it touches and you'll need a smock, a work area, and probably gloves.
See what happens is that where the print head parks there is an ink absorber and below it is an ink well. The ink absorber is a sponge like arm that cleans off the cartridge and the well catches the loose ink. Inkjet printers are for the most part not designed to last past a few years, so few printers have a method for emptying these. When they become full the printer will start leaking ink in torrents but will continue to function normally for quite a while until it fills every nook and cranny of the printer. While all you notice is a sightly higher consumption of ink.
By the time you start visibly seeing the ink come out of the printer, the inside is a huge mess, and when I say huge I mean without cursing, words just can't express how nasty and ink smeared it is.
Aug 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
You correct about the collector but you can empty it as well. With the printer unplugged. Move the carriage to the left manually. Here comes the hard part. Glued to the top of the collector is a piece of foam. You'll need to remove this, try not to rip it. Clean out the collector & wash the foam. Let them both dry. Some people use a syringe to pull out most of the ink.
Cotton swads help too. A small screw driver pushing down on a light cloth to pull out the ink. It's not easy, this i promise.
You can use a blow dryer to help dry, just don't melt the parts. Use super glue & replace the foam. Plug in the printer & print a test page out. The next time you need to replace your ink cartridge's make sure there is no build up of ink in the cartridge holder. Use soapy water & a clean cloth to clean it out. After the cartridge holder dries use some alcohol & cotton swab & clean the copper contacts from soap residue in the cartridge holder.
If everything goes well your good! Time for you to start helping at FixYa..
Good Luck & Kind Regards.
Need more help feel free to ask.
Mar 21, 2008 | HP PhotoSmart 1115 InkJet Printer
Printing light colors does not work
You RINSED the printhead???
I wouldn't do that again.
Try taking a damp cloth and dabbing it against the printhead nozzels until you get lines forming on the rage from the ink (the nozzels you're having trouble with specifically).
Oct 29, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
