Question about Zanussi ZCM611X Dual Fuel (Electric and Gas) Kitchen Range
Picture of a lock on the display and oven will not work
I have just bought a house with a Zanussi ZCM611X with no manual and the oven will not work. There is a picture of a lock on the diplay. Any ideas please how to get it working?
Thanks
  • 8,197 Answers
You can get the manual here. You need to sign up for free though.
http://kitchen.manualsonline.com/manuals/mfg/zanussi/zcm_611.html?s=fpw
Good Luck and Please Rate FixYa!
Posted on Jan 08, 2009
My zanussi zpb 1260 oven has stopped working after a pyrolytic clean. I set the oven and the display is correct but after a couple of seconds the the temp goes to 20 and nothing happens, tried switchi
Go to Zanussi . com select UK then manuals you will need more information a serial number and then download it, there should be an answer in there okay.
Regards
John
Nov 02, 2014 | Zanussi Ovens
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
Rented apartment and zanussi ceramic hot is displaying letter L on the hob plate control. There are no manuals around but unit looks new.
The "L" indicates that the child safety lock is on.
You haven't stated which exact model you have, but on most Zanussi's you turn the hob on and then press and hold the + and - buttons together until the display changes from "L" to "0".
Note that on some models you must do this every time you turn the hob on, on some others the lock can be disabled.
Jun 16, 2011 | Ovens
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Jun 21, 2008 | Zanussi ZBS963X Electric Single Oven
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Zanussi zbf 760
Gently but firmly pull one of the other buttons out and use that to reset it... you can buy new buttons on ebay
Oct 03, 2017 | Zanussi ZBF660 Electric Single Oven
How do i set the clock?
no but if u call zanussi customer care they will send u an instruction booklett number is 08705727727 op 3 hold op 2 op 2
May 30, 2007 | Zanussi ZHF470 Electric Double Oven
Ovens
if the oven fan and light are not working, then the clock probably needs setting. if oven fan and light work, but no heat, then the problem is probably the circular element round the fan. remove the back panel of the oven and you can often (but not always) see the damage. replacement of the element is straightforward
May 06, 2007 | Zanussi ZBF660 Electric Single Oven
Zanussi ZCM611X Dual Fuel (Electric and Gas) Kitchen Range Logo
208 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
