Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Water on floor
We bought new Frigidaire galaxy appliances 14 months ago, including fridge with ice maker. When we returned to condo after a month's absence (with fridge unplugged) we found water on floor. Could not find source of it, so cleaned up an put it back. Fine for one day and then water on floor again. Pan in bottom was dry. Is it possible that in defrost cycle water is not draining in pan?? Any suggestions? What can I do?
  • 69 Answers
Is possible that the plastic tube that leeds in the pan is obstructed or in a wrong position, check if water goes in the pan just put some water trought from the inside hole in the fridge and check if it reach the pan, maybe the inclination of the fridge is not sufficient, ( it has to be inclined to the wall direction so the water slides on the back inside wall of the fridge. can also be poor insulation of the fridge, so the outside surfaces come wet because of the hight air temperature outside and the cold surfaces of the fridge, then the water slides down the floor...make sure about air ventilation around the fridge!...I hope it was useful!
Posted on Jan 08, 2009
How to fix Frigidaire galaxy ice water panel
Probably have a dispenser micro switch burned out at the dispenser. What is the fridge model number?
APPLIANCE 911
Nov 06, 2015 | Frigidaire Refrigerators
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire side by side frost build-up by ice-maker
I had the same problem. After 6 months I contacted Frigidaire about it. They made arrangements with a local factory service repairman. Be sure you have your model and S/N available. The repairman came to my home, verified the problem and returned a week later and installed the replacement door dispenser. Problem solved.
Jan 14, 2018 | Frigidaire Refrigerators
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
Apr 16, 2009 | Refrigerators
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Nov 12, 2008 | Frigidaire FRS266ZDSB Side by Side...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerator does not cool. Electrolux FRIGIDAIRE we moved into a new construction condo and all appliances were new we liveed in it for 6 weeks frige was fine but loud it is a model GLRT 13TEW4 serial...
If the unit is less than 1 year old call Frigidaire factory service. In the mean time check in the back of the freezer or in air channels for frost build-up. It may indicate a defrost problem or air leak. still best to have factory tech check if in warranty.
J
Jun 13, 2008 | Refrigerators
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
177 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
