Antenna in broken
Antenna in broke off the back of my Symphonic wf203. can I fix it myslef or need to bring it in. i need the silver box inside the tv/that is connected to a green board.
  • 133 Answers
It can be fixed, it is called a tuner, if you can solder, you can order a new tuner from the manufacturer, and unsolder the old one , and solder on the new one
Posted on Jan 09, 2009
Put my tv on game mode nothing happens ita a symphonic wf203
Check whether signals from Xbox is compactable to TV inputs. Check the inter connection cables.
Jun 05, 2012 | Symphonic Televison & Video
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
I need a code to control a symphonic tv model wf203 using a vizio universal remote.
Setup codes for Symphonic TV with Vizio VU R8 Universal remote control are:
Oct 09, 2011 | Televison & Video
The temporary fix for this issue never lasts and it will soon break again. I have seen some shops charge over 100 dollars to get the TV working again, but later the part breaks off again. The threaded part that is broke is from the tuner that is on the main board.
The only real way to fix the problem you have is to purchase a new main board.
Next time use a "slip" connecter (not a threaded one) on the back of the TV for the cable connection.
Oct 06, 2010 | Televison & Video
Antenna bolt broke, how to fix antenna base.
This is probably way more information than you need, but here goes. I just had the same problem with my dads 2001 YUKON and wanted to put the stock wire back. It was not easy, but it can be done.
Remove the glove box, and plastic side panel on the dash
As you are looking through the removed area, there is a silver computer there, remove the bracket and move this computer.
Behind the computer there will be the plug in for the antenna. One side goes to the radio, the other to the fender.
Unplug the cable, and tape/fasten a length of wire to it so that when you pull it out, you have a guide to get the new wire back through the firewall.
Remove the old ant. and then take the guide wire and fasten to the new cable. Pull this guide wire through while someone else is feeding from the fender area.
Replug it, and reinstall the computer and glove box door.
Also, be aware and make sure that the new cable with stud matches the ant. mast. GM changed the size of the stud (for unknown reasons)and you may need to get a new matching mast. I could not use my old one
Dec 01, 2009 | 2001 Chevrolet Silverado 1500
Cannot connect the coverter box
When you have your converter box hooked directly with coax to your tv, is your antenna then plugged into your converter box in the "antenna in" port? What do you mean by it doesn't work? Does it say no signal? If so, you just need a stronger antenna. If not, you may have a defective box, bring it back to the place you got it and see if they can help.
Dec 27, 2008 | Symphonic ST420FF 20" TV
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Broken Cable Jack on c27a24t
You should take this to a service shop to have it properly repaired. They may have to order a new tuner module if the circuit board inside has been damaged.
There are safety issues with grounding and AC mains isolation with this connector.
Servicing this can have serious safety issues. Take the set to a service center if you want it repaired.
For the average TV set, the tuner module is rather expensive. It can be in the area of about $70 to $120 depending on the model. There is about 1 hour of labour involved if there are no problems to change it.
You may be lucky, and the service tech may be able to fix the connector back to the tuner case or have a way to change it.
If the set is more than about 5 years old the tuner module may no longer be available.
Jerry G.
Apr 19, 2008 | Zenith C27A24T 27" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
