Question about Microsoft Xbox 360 Console
Xbox 360 disk drive does not close
I was playing my 360 this morning and then it made a horrible noise so i opened the disk drive and closed it and it opened again . the disk drive does not stay shut
    Scholar:
  • 39 Answers
Hi there. There is a solution out there, called the 'rubberband mod'. By tieing a rubberband to the rail on which the laser slides, you restrict the movement of the laser, and force it to stay within a readable range. It is essentially a bumper. Here's a link with a video that gives all the info on it; http://www.360mods.net/News/article/sid=71.html Hope that helps ! cheebster.
Posted on Jun 18, 2007
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't read.by the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Oct 25, 2010 | Microsoft Xbox 360 Console
Xbox 360
Most likely your disk or dvd drive is dirty. Run the disk through a disk cleaner and run a dvd cleaning disk through your drive.
If that dos not work, try removeing disk, close drive, turn off console, unplug power supply, wait 10 or 20 seconds, then reconnect power supply and try again.
If that fails, assumeing other disks will read, your disk may have a major flaw. You can check with your local game store, they often have a machine that may restore your disk, (most places that I know of charge like 1 or 2 $).
Mar 10, 2010 | Microsoft Xbox 360 Console
Xbox 360 disk drive problems
Yes , open up your CD drive remove
the top cover ,turn the belt on the pully
CC like you did before to pull the tray out
till it stops. There should be two small tabs
on etch edge at the end of the tray lift them
and pull this should relase the tray from
the drive . now look down in the frount
of the drive there are to leaf switches on
etch side the they should be straight.
the cats may have bent one of them with
his paws . I guess the cat will stay away
from your xbox now.
hope that help a little
Rob
Sep 20, 2009 | Microsoft Xbox 360 Console
Games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Jun 01, 2009 | Microsoft Xbox 360 Console
Xbox 360: disk drive
try reseting the system in the system settings this, is sometimes caused by an update not downloading and or installing correctly. once you reset to default, try updating  the system on xbox live. if this continues you might have a drive issue. good luck....
May 27, 2009 | Microsoft Xbox 360 Console
One day i was playing halo 3 and my disk drive starting making wierd, grinding noises and stopped then after the noise stopped my disk would stop spinning and now eveytime i try to read my disk my motor...
This hard disk is a easy fix, You can buy a new one for the fraction of the cost, All you have to do is slip this off the unit and apply an new or even a used hard drive. Here is some links for some hard drives http://catalog.ebay.com/Microsoft-Hard-Drive-120-GB-9Z600001-for-Xbox-360_W0QQ_fifptsZ1QQ_pcatidZ413QQ_pidZ70884347QQ_trksidZp3286Q2ec0Q2em271
you can get some for under 30 bucks. if this information helps please rate accordenly Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Microsoft Xbox 360 Console
XBox 360 disc tray open
i have the same problem i called xbox and they said that it needs a new disk drive and it would be 100.00 so if you want it fixed youll nedd to call 18004myxbox and they will give you all the info on were to send it or for 100.00 more you can buy a new one like i did
Apr 28, 2009 | Microsoft Xbox 360 Arcade
My xbox 360 drive will not open or close unless i use the emergency eject button yet it plays disks fine.
That's a common problem with the DVD-Drives, this is going to fix it...
http://xbox-experts.com/e/tutorial.php?n=dvdopentray
I hope this helps.
Kind regards,
Wilhelm@Xboxexperts.com
Mar 08, 2009 | Microsoft Xbox 360 Console
Unreadable disk
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Apr 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
163 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
