Question about Canon PIXMA iP1600 Printer
Using refilled cartridges
My Canon Pixma iP 1600 won't accept refilled cartridges, although it has done so in the past. Is there a way I can bypass the message that says the cartridge has not been installed correctly?
Cartridges eletrics may be dead or you can turn of ink monitors in the software i.e my cpu, control pannel, printers and faxes right click canon printer select properties tab up top somewhere.
Posted on Aug 02, 2007
    Genius:
  • 2,985 Answers
Are these chipped cartridges/ If so you will need to get hold a cartrisge re setter Most ink suppliers/manufacturers do them.
Posted on Jun 02, 2007
Canon ip 7240 i used refill ciss but 4 flash
Hi, My name is Liam from rihac, although we do not sell printers I work very closely with them via our inklink products. When a printer flashes 4 times this is a sign that an ink tank is not installed correctly or that the cartridge will need to be replaced as it is low on ink. As you are using a CISS the cartridges will always have ink in them. To bypass this error all you will need to do is press and hold the RESUME button on the printer for 10 seconds and this will turn off the cartridges ink status monitor and allow you to continue printing.
Canon Error Codes
I hope I was of help to you
Oct 30, 2013 | Office Equipment & Supplies
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
Message tells me black ink cartridge empty when I just put new one in
if you are using a refilled cartridge the printer don't accept them, you need to use the proper canon ink cartridge, if you are using the canon cartridge you have to press the stop botton for 5sec for accepting the new cartridge.
Dec 24, 2010 | Canon Pixma MP500 All-In-One InkJet...
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How to refill canon pixma ip1600 ink colour? the hole is too small.
IF YOU HAVE BUY THE INKS THEN YOU GET NIDLE AND SIRING THEN YOU WILL USE THE TECHNIC DOCTOR USE TO SWAP THE LIQUID FROM THE CONTAINER AND INJECT IT IN THE BODY YOU WILL USE THE SAME TECHNICS GET THE INK IN TO THE SIRING AND PUT IT IN THE CARTRIDGE BUT MIND YOU LOOK AT THE HOLES VERY WELL RED HOLE WILL BE MARK RED, BLUE WILL BE MARK BLUE WHILE YELOW WILL BE MARK YELOW SO ALL YOU NEED TO DO IS FOR YOU TO PUT THE INK IN THE RIGHT HOLE IN SOME CARTRIDGE THE HOLES WILL GUIDE BY A OBJECT REMOVE CAREFULLY THEN AS YOU FINISH REFILLING EACH HOLE PUT THE OBJECT BACK.
Nov 13, 2008 | Canon PIXMA iP1600 Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Refilling a cartridge
You need to use a very thin needle (25 gauge medical needle works well) on a syringe. There is a tiny hole in the canon 40 cartridge under the label which you need to fill. To refill the color cartridge (canon 41) as you look at the cartridge, the hole at the top is magenta, the hole to the left is blue and the hole to the right is yellow, use a separate syringe and needle for each color. Every now and then you will need to use some cartridge cleaner to soften/clean the sponge in the cartridge. I use 0.5cc of cleaner then let sit overnight before adding ink. You need to be sure the label is replaced well or use good tape to keep the ink from escaping.
Sep 06, 2008 | Canon PIXMA iP1600 Printer
Canon iP 1600
dear
you can refill your catridge, open the label .... make a whole with knife or something edge, and the red color in center position, the yellow in the right position , and the blue in the left position
don't refill too full, about a 30 cc inks
oke maybe it can help you
thks
cropp
Feb 19, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
185 people viewed this question
Clive
Clive
old marine
old marine
