Question about HP PhotoSmart C4280 Laser Printer
Printer is saying i have black cartridge in the printer
I have my cartrige in and it was about 3/4 the other day when i used it. it is not detecting the cqartrige at all.
  • 69 Answers
Take it off the printer and clean the contacts and maybe the ink is finished, depends how much u used it! the meter is not like the car ones! can be faulty...
Posted on Jan 08, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Stylus R220. Just replaced the black ink and it still won't let me print. Keeps saying REPLACE CARTRIDGE. I'm using a Mac. Supply Levels Utility is completely useless. Says Information Not...
Try to clean cartrige and cartrige carrier conector place with soft erager.Then put cartrige into cartrige holder then gentaly push top of the cartrige sothat a `cat' sound happend, then turn on printer.
I think you will relive
Thank you
Sep 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My new black ink cartridge doesn't work. The light shows like the other cartriges and there are no error messages. All 3 colors are working. - I performed the 'deep clean' for the black cartridge twice,...
I would like to advise you to remove the printer and uninstall the printer software from your PC, then reinstall the printer software to the PC, then connect the printer to be detected and installed. Now try to do the test described and see it it works out. Hope I could help . Good day
Aug 13, 2010 | Office Equipment & Supplies
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
My printer say no cartrige for C M and Y at the same time and when i change the cartrige it says the same
all brother printer has no chips on the cartridge, they are all detecting through sensor,you can find it on the ink cartridge area.
Sep 04, 2009 | Brother MFC-465CN InkJet Printer
Black Cartridge
Hi - If you are saying that the right side cartridge is the black cartrige that you have replaced, then I have two suggestions that may help. If the cartrige is a new HP genuine product I would take it back. If not, I would return the cartrige you have and buy a genuine HP for the printer. Though an expensive solution, there is always a chance of defects from either party. The remanufactured or refilled cartrige will have a date on it. The circuit board on these can wear out and then not be recognizable over time. Second suggestion if you have not already done this, a cotton swab or Q tip dipped in distilled water(damp only) to wipe down the circut board on the printer where the cartrige will connect to it, may help. Turn off the printer to do this. Make sure it is dry when you turn it on and reinstall the new cartrige. Hope this helps.
Jul 07, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Says new bnlack ink cartriges are empty when they are new
1st check the little gold plates on back of the cartridge.
clean them off and were they make contact to the printer.
If that don't work.
Download SSC Service Utility. (Voids warrenty use at own risk free program)
If that don't fix it there is still one more thing you can do.
Get a chip restetter for your cartridges.
(this one is not free)
This will reset the chip on your cartridge and make the printer think its a new one.
I use both programs works great.
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
HP PhotoSmart C4280 Laser Printer Logo
35 people viewed this question
Ben Johnson
