Question about Gateway 420GR PC Desktop
Monitor does not come on when powered on, it says no input signal
I have a gateway 420gr when I push the power button to turn it on the computer's blue power light comes on the fans come on loud like they are in hypermode, they should quiet down after a few seconds but they dont. they just stay in the loud hypermode and the monitor does not detect a signal at all, it just stays blank the whole time. when this first happened i had a you tube video going and the monitor all of a sudden shut off and said no input signal. Any ideas what the problem may be?
  • d_j_l_04 Jan 08, 2009
    I am just using the built-in integrated video port
    President:
  • 1,179 Answers
Check your video card. It sounds like it has went bad. Hope this helps.
Posted on Jan 08, 2009
  • Roy Lonsinger
    Roy Lonsinger Jan 08, 2009
    Then the intergrated video on the motherboard may have went bad. Try installing a video card that is compatible to your motherboard in the open pci-e if a newer computer or the agp slot if older. If the installed card works then you know for sure it is the built in graphics that went bad. Hope this helps.
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway lcd monitor goes off and on!
First, check to make sure the input selection switch isn't stuck, after unplugging the monitor power cable. It sometimes can get stuck, or just become damaged.
If this isn't it, maybe it's time for a new monitor.
Feb 14, 2012 | Gateway FPD1975W 19" LCD Monitor
Power Button lights up when pushed, computer comes on, but doesn't stay on. What can cause this?
one cause of this is that there is a problem with the motherboard or the video card.
try to turn off the desktop
unplug the cables
press and hold the power button for 5 seconds
replug the cables
turn on the desktop
if symptom persists, call gateway for possible repair
Jun 15, 2010 | Gateway 420GR PC Desktop
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FDP1975W Monitor Power Button Not Working
i would advice you to take your monitor to a technician, but if you are not ready, please leave the monitor on and make sure it is connected to ups u can now turn it on and off from the ups, if you continue the menu, Auto fit etc stuff, you might damage or disorganize the settings of your monitor which might cost you more. thanks
Jul 17, 2009 | Gateway FPD1760 17" LCD Monitor
My gateway 420GR desktop will power on but on the monitor only display no input signal. The PC will also not turn off at the power switch.
Sounds like the power button on your monitor is not on, is the light on the monitor yellow and dim or bright when you start the computer? Make sure the monitor is on. If you hold the power switch in for about 10 seconds the power will turn off. But that is not the recommended way to shut your computer down. Use your start button and log off or close that way. Good Luck.
Oct 28, 2008 | Computers & Internet
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor Goes Black
Try to start in safe mode and check if you can change some of the video settings (resolution, refresh rate, etc). Maybe one of these settings is such that the monitor cannot handle properly. To get into Safe Mode, press F8 as soon as you see the Gateway logo on the screen while booting the PC.
Aug 08, 2007 | Gateway FPD2275W LCD Monitor
Gateway 420GR PC Desktop Logo
361 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
