Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Where do i put remote reciever for fan install.
It wont fit inside of fan cieling finish cover
  • 37 Answers
I'm not completely sure what the fan mounting bracket (that screws to the electrical box) looks like on this model, and I'm not sure what type of remote you have, but remote receivers usually slide in between the ceiling and that bracket (slide in with antenna wire first). Or the other type goes inside the very bottom of the fan, the part where a light kit gets attached (these receivers look like a donut).
Posted on Jan 23, 2009
How do you mount the cieling fan
Put the hanging bracket on the electrical box. Assemble fan top with rod & canapy & hang on bracket. Wire fan & connect blades and bottom cover.
Aug 19, 2014 | Kichler Lighting Dryers
WHERE THE REMOTE CONTROL TRANSMITTER IS LOCATED IN THE CEILING FAN
The transmitter is the piece you hold in your hand, the reciever is the part that fits inside the ceiling fan. It usually goes inside where a lamp attaches to the bottom of the fan.
Aug 01, 2014 | Hunter Sontera 52" Ceiling Fan with...
How to fix a wobbly ceilng fan
wobbly cieling fan
1. make sure all mounting screws between the fan and the ceiling are tight. There is probably an electrical box mounted in the cieling that the fan is screwed into. I would turn the fan light on and then keep flipping breakers off, on at a time ,to see which breaker turns off the fan light. leave the fan light breaker off and you can unmount the fan from the cieling electrical box. The electrical box may have several holes in it for mounting screws and prehaps there are some holes left empty in the box that you can put more wood screws into to help keep the electrical box more firmly mounted and that may help lessen the wobble.
Its ok to bend the electrical wiring aside to put more screws in. Just be reasonably gentle with the wiring and then bend it back somewhat to where it was before you started. make sure that wiring does not get pinched between the fan and the electrical box and that all wiring resides inside the box.
#2 This is harder to do. you need to balance the blades for the fan ,similar to how a lawnmower blade is balanced after sharpening and before remounting the lawnmower blade on the mower. also kinda like balancing a car tire. I have a lawnmower blade balancing fixture that i bought at the lawnmower shop, but i dont know if there is a fan blade balancing fixture that you could buy from somewheres. Maybe try google.com,bing.com or ask.com and type into the search box fan blade balancer
or fan blade balancing fixture or fan blade balancing jig.
PLEASE read the directions or SPECIFICATIONS before you buy the fan blade balancer, only to find out that it only fits 9 inch diameter fan blades, and your blade is 2 4or 36 inches long.
The balancer may have to fit a certain diameter hole at the center
of the fan blade. When you finally find out which side of the fan blade is heavy, you have to grind , with an electric grinding wheel, some material off the heavy side of the blade so that it is the same wieght as the light side of the blade.
Try to imagine a cone shaped center[like step drills] like the capital letter V ,only up side down, so that the point is up. ON the underside of the inverted V is a needle tiped post that upside down V can pivot in any direction on. The hole in the middle of a lawnmower blade is centered somewheres on the outside of the inverted V, depending on the diameter of the hole in the lawnmower blade. The heavy side of the mower blade will go down and may touch the level asphault or the table top, depending on where you placed the balancing fixture. THen i would grind off metal until the heavy side can up to be level with the light side of the mower blade and it was considered balanced.
an appliance repair parts store may sell fan balancers, but if the would fit your cieling fan, better ask before you waiste your money on something that wont work for what you want.
Try calling up customer service of the manufacturor of your ceiling fan and ask about repair service for your brand fan.
see what repair service has to say, im sure many others have asked them about wobbling fans.
so they should have all the answers down pat.
Two more thoughts.
1.
.MAKE SURE ALL SCREWS THAT HOLD FAN BLADES ON TO THE HUB ARE THERE AND are TIGHT. one loose fan blade mounting screw or one missing fan blade screw will unbalance the whole thing and cause wobble.
2. the fan motor shaft bearing could be worn out or round or even egg shaped. If this is the cause, the motor must be diaassembled and new fan shaft bearings installed or the fan motor must be replaced.
good luck and have fun!
Sep 22, 2013 | Hampton Bay 24002 Ceiling Fan
I purchased a Turn of the Century 52 inch remote ceiling fan, model 355-6786/6787/6788. After installing it I couldn't get the high speed button on the remote to activate the high speed on the fan. All...
I purchased a 'Turn of the Century-Apollo' model 355-6786 cieling fan. The only problem is no fan blade mounting bolts and nuts, instead I have 2 packs of mounting screws. I've dialed the Customer Service Department to no avail. Is there an unpublished WEB site?
Jun 26, 2010 | Casa Vieja Turn of the Century Antique...
How do I get my hampton bay antigua fan down from the ceiling
first you will need a ladder and a screwdriver/phillips a couple wire nuts or electrical tape.at the "top" of the fan you will see a bowl shaped cover it will have usually no more than two screws in it..loosen or remove those screws to access the fan hanger inside.once you get that far inside you will see several wires .undo each wire seperatly and cover with a wire nut or electrical tape(please make sure your power is off to that circuit) once you have unhooked all the wires from the fan and secured them out of the way. lift the fan out of the hanger itself (sometimes it is easier to remove each blade from the motor housing before removing the fan from its hanger ) those screws can be found at the base of each blade on the motor housing..If you are moving or adding a cieling light be sure to remove both parts of the fan hanger..the second part will still be attached to the cieling..usually two screws holding it into place..if just replaacing the fan,,you can sometimes leave the second part there and hang the new fan with it..
Jul 30, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
I have a 4 blade HB cieling fan. 2 above 2 blades. Where to put the reciever seems to be no room. Instructions were missing.
The receivers in my 3 hampton bay fans actually slides into the upper portion of the hanging bracket ( the thing you screwed into your ceiling fixture that the fan hangs off of)..
It fits rather nicely once you make room for it with the wiring etc
Hope this helps.
Jul 07, 2009 | Hampton Bay 24002 Ceiling Fan
Wireless ceiling fan
there are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
http://www.csnceilingfans.com/Ceiling-Fan-Remote-Controls-C14870.html
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
Aug 16, 2008 | Dryers
Hunter fan remote control
Logitech makes a universal remote that uses RF (radio frequencie) which could be programmed for the cieling fan.
Jun 08, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay Carriage House II
I went ahead and hooked up the wires, and then zip stripped the wireless receiver to the side of the motor mount. Works fine and fits inside the canopy (motor cover).
May 30, 2008 | Hampton Bay 13087 70450 Carousel II...
Hampton Bay 54in. Covington with remote control
Make sure the power wires from the ceiling mount are still in the electric box. Then have them come from the side near the screw mounting area. In otherwords, not through the center hole. In the center of the black metal part - there is where you put the reciever. It will fit literally resting on the black metal.
Aug 31, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
75 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
